Hi Brent,
Thanks for your email.
This seems really odd. Could you change the logging level to 'fine', and try the request again?
For the kml request I get:
8399097 [FINE] org.vfny.geoserver.servlets.AbstractService - reading request: service=WMS&request=GetMap&format=application/vnd.google-earth.kml+XML&width=1024&height=1024&srs=EPSG:4326&styles=snet8&layers=topp:current_kcci&bbox=-180,-90,180,90&BBOX=-93.84408985736377,41.49898648304644,-93.66650786674322,41.61480866506157
8399097 [FINE] org.vfny.geoserver.global.Data - getting type topp:current_kcci
8399098 [FINE] org.geotools.data.postgis.PostgisDataStore - get Feature source called on current_kcci
8399098 [FINE] org.geotools.data.postgis.PostgisDataStore - returning pg feature locking
8399098 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
8399098 [FINE] org.vfny.geoserver.wms.requests.GetMapKvpReader - establishing snet8 style for topp:current_kcci
8399099 [INFO] org.vfny.geoserver.servlets.AbstractService - handling request: org.vfny.geoserver.wms.requests.GetMapRequest@anonymised.com
8399099 [FINE] org.vfny.geoserver.servlets.AbstractService - strategy is: PARTIAL-BUFFER
8399100 [FINE] org.vfny.geoserver.wms.responses.GetMapResponse - setting up map
8399100 [FINE] org.geotools.data.postgis.PostgisDataStore - get Feature source called on current_kcci
8399100 [FINE] org.geotools.data.postgis.PostgisDataStore - returning pg feature locking
8399100 [FINE] org.vfny.geoserver.servlets.AbstractService - mime type is: application/vnd.google-earth.kml+xml
8399101 [FINE] org.vfny.geoserver.servlets.AbstractService - content encoding is: null
8399101 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available connection.
8399103 [FINE] org.geotools.data.jdbc.ConnectionPool$ConnectionListManager - Connection closed - adding to available connections.
8399103 [INFO] org.vfny.geoserver.wms.responses.map.kml.EncodeKML - Layer () rendered with KML vector output.
8399104 [FINE] org.geotools.styling.StyleImpl - number of fts set 1
8399104 [FINE] org.geotools.data.jdbc.JDBC1DataStore - calling sql builder with filter [ geom bbox POLYGON ((-180 -90, -180 90, 180 90, 180 -90, -180 -90)) ]
8399105 [FINE] org.geotools.data.jdbc.JDBC1DataStore - sql is SELECT "oid", "station", encode(AsBinary(force_2d("geom"), 'XDR'),'base64'), "network", "sname", "tmpf", "dwpf", "drct", "sknt" FROM "public"."current_kcci" WHERE "geom" && GeometryFromText('POLYGON ((-180 -90, -180 90, 180 90, 180 -90, -180 -90))', 4326)
8399105 [FINE] org.geotools.data.jdbc.JDBC1DataStore - About to execute query: SELECT "oid", "station", encode(AsBinary(force_2d("geom"), 'XDR'),'base64'), "network", "sname", "tmpf", "dwpf", "drct", "sknt" FROM "public"."current_kcci" WHERE "geom" && GeometryFromText('POLYGON ((-180 -90, -180 90, 180 90, 180 -90, -180 -90))', 4326)
8399105 [FINE] org.geotools.data.jdbc.ConnectionPool - Getting available connection.
8399108 [INFO] org.geotools.renderer.style.SLDStyleFactory - Bad file name in SLDStyleFactoryserif
java.io.FileNotFoundException: serif: No such file or directory
8399109 [INFO] org.geotools.renderer.style.SLDStyleFactory - null input stream
What is weird is that when you specify for a kmz result, it is returning valid kml in the zipped up kmz file. But for just regular kml it isn't working. There seem to be very few features as well, so it isn't a size issue.
Should only be 71 features.
The style also looks fine. Although looking at the request you aren't using the style you specified.
Good point. It should be 'snet8'. I think I just gave you an older URL i have been testing with.
I tried to do a getCapabilities request but that is also getting truncated part way through the response. A describe feature type request is also not working. So something weird is going on here.
Hopefully it isn't me!
Can you try the same dataset but as a shapefile instead?
Ok, I dumped the shapefile out of the database and added it, I changed the style to use the UPPERCASE attribute.
I'm getting the same errors. kml hangs, kmz has double
http://mesonet.agron.iastate.edu/geoserver/wms?service=WMS&request=GetMap&format=application/vnd.google-earth.kml+XML&width=1024&height=1024&srs=EPSG:4326&styles=snet8_shp&layers=topp:current_kcci_shp&bbox=-180,-90,180,90&
thanks and sorry,
daryl
* Daryl Herzmann, RHCE
* Program Assistant -- Iowa Environmental Mesonet
* http://mesonet.agron.iastate.edu
