[Geoserver-users] Re: [Geoserver-devel] install errors
Hi Glenn,
Glad to hear that it is working now.
Yep, I am using Mapbuilder for a project right now (when it is done I will announce it on the list, but I want to get it perfect first).
Geoserver has built in demos that are done with maobuilder, you can check them out in the demo section of the web-admin page (http://localhost:8080/geoserver/demo.do). Mapbuilder comes with a bunch of good demos. I used them as a reference for building my own maps.
You can sign up to the mailing list here: http://sourceforge.net/mail/?group_id=25086
cheers,
Brent Owens
(The Open Planning Project)
Hazelton, Glenn wrote:
Thanks
I figured out that I have the java_home env. Variable set to the jre
instead of the sdk.. now it is working.
Next step is to sort out mapbuilder
Are you using it?
Any helpful hints appreciated.
Thanks for responding
and
How do get on the list-serv?
glenn
-----Original Message-----
From: Brent Owens [mailto:brentowens@anonymised.com] Sent: Thursday, April 06, 2006 9:02 PM
To: Hazelton, Glenn
Cc: geoserver-devel@anonymised.com
Subject: Re: [Geoserver-devel] install errors
Hi Glenn,
That error is caused by not having the SDK version of java installed. It
looks like you just have the JRE version.
You can download the SDK version here: http://dlc.sun.com/jdk/j2sdk-1_4_2_07-windows-i586-p.exe
If you have any other questions feel free to ask.
Brent Owens
hi
i am not very familiar with the java jargon found in the help docs
what i have done
1) installed geoserver on windows 2000
2) tryed to start it... a dos window appears and alot of text scrolls along. the window never closes
3) i then try to start the geoserver administration and i get this
error
*HTTP ERROR: 500
Unable+to+compile+class+for+JSP%0A%0AAn+error+occurred+at+line%3A+%2D1+i
n+the+jsp+file%3A+null%0A%0AGenerated+servlet+error%3A%0A++++%5Bjavac%5D
+Compiling+1+source+file%0A%0A%0A*
RequestURI=/geoserver/
i am running j2re1.4.2_03
any help appreciated
Glenn Hazelton, PhD.
MWRA
2 Griffin Way
Chelsea, MA 02150
617-305-5526
glenn.hazelton@anonymised.com
