Richard,
The problem was with your .sld files.
They all have a line like this:
<FeatureTypeStyle>
<FeatureTypeName>feature</FeatureTypeName>
<Rule>
The "<FeatureTypeName>" clause says that the rules should only be
applied to featuretypes that are named "feature". Your featuretype is
"serie_rouge" so the renderer didnt even try to draw anything.
To fix either:
1. remove the the "<FeatureTypeName>feature</FeatureTypeName>" line
2. or replace it with "<FeatureTypeName>serie_rouge</FeatureTypeName>"
dave
ps. I did make some other changes in the literender to be wiser about
rendering multi* objects - for multipoints.
This mail sent through IMP: https://webmail.limegroup.com/
At 06:44 PM 4/14/2005, dblasby@anonymised.com wrote:
Richard,
<FeatureTypeStyle>
<Rule>
To fix either:
dave
Note that 'feature' used to work, and 'Feature' still does. This is because all feature types decend from 'Feature'.
James
