ccing the users list, since others will be curious.
And it'd be great if you could update the Mac OS X installation
instructions.
JAVA_HOME you set the same way as CATALINA_HOME, export it in your
.bash_profile
export JAVA_HOME=/path/to/your/installed/java
Chris
epifanio wrote:
yes it was a permission problem,
now it find the file,
but i need to set something in a "configuration file"
it ask me for a java environment variable.see the log:
computer-di-epifanio:~ epifanio$ $CATALINA_HOME/bin/startup.shThe JAVA_HOME environment variable is not defined
This environment variable is needed to run this program
computer-di-epifanio:~ epifanio$in which file i must set java environment ?
there are other things to set ?thanks a lot for your precious help!
Il giorno 09/feb/07, alle ore 18:30, Chris Holmes ha scritto:
Could be permissions?
Try a 'chmod 775' to catalina.sh
Chris
epifanio wrote:
(the first step needed to install geoserver on osx 10.4.8 intel)
i'm tring to install tomcat
i've downloaded the 5.0.28
binary package
core : zip file
i've copiyed it in :
/source/jakarta-tomcat-5/
and i added this line to my .bash_profile :
export CATALINA_HOME=/source/jakarta-tomcat-5/jakarta-tomcat-5.0.28
i type in the bash shell :
chmod a+x /source/jakarta-tomcat-5/jakarta-tomcat-5.0.28/bin/startup.sh
and then i tried to start tomcat using :
but i've this log :
Cannot find /source/jakarta-tomcat-5/jakarta-tomcat-5.0.28/bin/ catalina.sh
This file is needed to run this program
what i'm wrong ?
the file "catalina.sh" is in the right path :
/source/jakarta-tomcat-5/jakarta-tomcat-5.0.28/bin/catalina.sh
thanks a lot for your help!
Massimo.
Il giorno 09/feb/07, alle ore 17:28, geoserver-users- request@lists.sourceforge.net ha scritto:On 2/9/07, epifanio <massimodisasha@anonymised.com> wrote:
hi,
i'm new to geoserver,
i've read on the geoserver site an " how to" install documentation
abour geoserver on osx tiger server edition.
i'm on osx tiger "client edition"
can anybody point me to an how to install "tomcat + geoserver"
on my OS ?
thanks for ant suggestion about.Massimo.
I just did it a few weeks ago and I wish I had taken better notes.
From memory; install Tomcat (I am using 5.0.28) and make sure it is
working. I do not remember any problems there. Use the
geoserver-1.4-war.zip (not geoserver-1.4-bin, and I would avoid 1.5 at
first as it has additional requirements)un-zip and un-pack the war, then drag geoserver into web-apps directory.
Restart Tomcat, and try localhost:8080/geoserver
I seem to recall changing something in web.xml or server.xml, but it
was not entirely specific to geoserver.I got it running without undue effort on OS X 10.4.8, if you have
problems please post specific details.Rich
!DSPAM:1003,45ccb3eb102822095110867!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Chris Holmes
