[Geoserver-users] Re: Layer Problem
Hi Brent Owens,
I am not working with WMS/WFS requests.
I use mapbuilder to display my layers. I usually add
the layer list in an xml file (as below)
<?xml version="1.0" encoding="ISO-8859-1"
standalone="no"?>
<ViewContext version="1.0.0" id="atlas_world"
xmlns="http://www.opengis.net/context&quot;
xmlns:xlink="http://www.w3.org/1999/xlink&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xsi:schemaLocation="http://www.opengis.net/context
http://schemas.opengis.net/context/1.0.0/context.xsd&quot;&gt;
  <General>
    <Window width="900" height="500"/>
    <BoundingBox SRS="EPSG:4326"
minx="11018.9990234375" miny="8970.806640625"
maxx="566147.3125" maxy="350142.8125"/>
Say my 1st layer size matches the BoundingBox info -
above and not the 2nd.
My 2nd layer is very small say - it may look like
below...
<BoundingBox SRS="EPSG:4326" minx="2.46677756309509"
miny="2.88622093200684" maxx="8.62069225311279"
maxy="26.6640968322754"/>
I Want to edit my shape files so that say both have
same size/scale say like 800x600 (extent, pixel or
whatever)
Anyone there ? who knows the procedure ?
I am not sure if this is right place to ask about
shape file modifications !
Muthu Veerappan
I'm a little confused as to what is going on.
So you have one very large layer (large in area:
bounding box size) and
another smaller area. Both areas show up when you make
a WMS request?
Then you add a third layer, that is also small, but it
doesn't show up
when you make a WMS request? Does the small layer fit
in the bounding
box of the larger layer, or does it fall outside of
it?
If the layer is really small, and you are viewing the
whole map, it may
be that you are zoomed out too far to see the small
layer. There is no
way to increase the size of the geometries so they are
viewable when you
are more zoomed out (that would wreck the data). WMS
requests cannot
modify the geometry of existing data. What you can do
is create a style
(SLD) for that layer and make the geometries really
"thick" so they will
show up more. And make sure that the mapbuilder config
file is set up so
the initial bounding box of the view contains all
layers.
Brent Owens
(The Open Planning Project)
muthu veerappan wrote:
Hi All,
I have 2 layers 1 small size and 1 big size (extent
For the big layer to view in mapbuider i need to
give
the below
<BoundingBox SRS="EPSG:4326" minx="11018.9990234375"
miny="8970.806640625" maxx="566147.3125"
When i add one more/new layer to this, that new
layer
is not visible since its extent or BoundingBox is
very
small !
Could you tell me a way in which i can bring both to
same size ?
Any reduction or enlargment is possible ? How to do
that ?
PS. Both are shape files (i have - as of now)
Waiting for your replies. :slight_smile:
Muthu Veerappan
PR.Muthu Veerappan (&#2990;&#3009;&#2980;&#3021;&#2980;&#3009; &#2997;&#3008;&#2992;&#2986;&#3021;&#2986;&#2985;&#3021:wink:
Mobile +971 50 4206576 (Dubai)
e-Mail - muthu@anonymised.com
Check http://www.periyakaruppan.com
Join http://www.buddhibase.org
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
