[Geoserver-users] Re: [Mapbuilder-users] SLD Question
It looks fine to me, but what it could be is the property name tag for your text symbolizer. Check and make sure that the label in it is correct. <ogc:PropertyName>TYPE</ogc:PropertyName>
It is case sensitive, so make sure it matches the column name of the data exactly.
Brent Owens
(The Open Planning Project)
olivier terral wrote:
hi,
excuse me i send the bad sld , look this it's the good WMC with<SLD>:
<?xml version="1.0" encoding="ISO-8859-1" standalone="no"?>
<ViewContext version="1.0.0" id="WMC vide de cadastre" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns="http://www.opengis.net/context&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd&quot;&gt;
     <General>
           <Window width="600" height="300"/>
           <BoundingBox SRS="EPSG:4326" minx="141.57875" miny="-44.26625" maxx="151.03125" maxy="-39.56375"/>
           <Title>tasmania</Title>
           <KeywordList>
                 <Keyword>tasmania</Keyword>
           </KeywordList>
           <Abstract>salop</Abstract>
   </General>
       <LayerList>
           <Layer queryable="0" hidden="0">
               <Server service="wms" version="1.1.1" title="My GeoServer WMS">
                   <OnlineResource xlink:type="simple" xlink:href="http://localhost:8080/geoserver/wms?&quot;/&gt;
               </Server>
               <Name>topp:tasmania_roads</Name>
               <Title>tasmania_roads_Type</Title>
               <Abstract>Generated from tasmania_roads_shapefile</Abstract>
               <SRS>EPSG:4326</SRS>
               <FormatList>
                   <Format current="1">image/png</Format>
               </FormatList>
               <StyleList><Style current="1">
                   <SLD>
                       <StyledLayerDescriptor version="1.0.0" id="sld vide" xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
                           <NamedLayer>
                               <UserStyle>
                                   <Title/>
                                   <Abstract/>
                                   <FeatureTypeStyle>
                                       <Rule>
                                           <MinScaleDenominator>0</MinScaleDenominator>
                                           <MaxScaleDenominator>1000000000</MaxScaleDenominator>
                                           <LineSymbolizer>
                                               <Stroke>
                                                   <CssParameter name="stroke">#FF0000</CssParameter>
                                                   <CssParameter name="stroke-opacity">0.75</CssParameter>
                                                   <CssParameter name="stroke-width">3</CssParameter>
                                               </Stroke>
                                           </LineSymbolizer>
                                       </Rule>
                                       <Rule>
                                           <MaxScaleDenominator>10000000000</MaxScaleDenominator>
                                           <TextSymbolizer>
                                               <Label>
                                               </Label>
                                               <Font>
                                                   <CssParameter name="font-family">Times New Romans</CssParameter>
                                                   <CssParameter name="font-style">italic</CssParameter>
                                                   <CssParameter name="font-size">14</CssParameter>
                                                   <CssParameter name="font-weight">bold</CssParameter>
                                               </Font>
                                               <Halo>
                                                   <Radius>2</Radius>
                                                   <Fill>
                                                       <CssParameter name="fill">#FFFFFF</CssParameter>
                                                       <CssParameter name="fill-opacity">0,85</CssParameter>
                                                   </Fill>
                                               </Halo>
                                               <Fill>
                                                   <CssParameter name="fill">#00FF00</CssParameter>
                                                   <CssParameter name="fill-opacity">1</CssParameter>
                                               </Fill>
                                       </TextSymbolizer>
                                   </Rule>
                           </FeatureTypeStyle>
                     </UserStyle>
               </NamedLayer>
       </StyledLayerDescriptor></SLD></Style></StyleList></Layer></LayerList>
</ViewContext>
Brent Owens a écrit :
Could you send us the full SLD with both rules? So far this one looks ok.
I have used SLD's many times with many rules, using filters and scale denominators, and they all work well.
Brent Owens
hi,
I try this method for my sld editor, but when i inserted two rules for example a TextSymbolizer Rule and a Polygon Rule , nothing appears on the map.
It seems to be that The Text Symbolizer rule doesn't applied because when i delete TextSymbolizer rule , layer appears.
Anybody can explain why?
Thanks in advance.
for information i use mapbuilder geoserver
<Layer queryable="0" hidden="0"><Server service="wms" version="1.1.1" title="My GeoServer WMS">
</Server>
<Name>topp:tasmania_cities</Name>
<Title>tasmania_cities_Type</Title>
<Abstract>Generated from tasmania_cities_shapefile</Abstract>
<FormatList>
</FormatList>
<StyleList>
   <Style current="1">
       <SLD>
               <NamedLayer>
                       <UserStyle> <Title/>
                       <Abstract/>
                       <FeatureTypeStyle> <Rule>
                               <MaxScaleDenominator>100000</MaxScaleDenominator>
                               <PointSymbolizer>
                               <Graphic>
                                       <Mark>
                                                       <WellKnownName>square</WellKnownName>
                                                      <Fill><CssParameter name="fill">#FF0000</CssParameter><CssParameter name="fill-opacity">0.75</CssParameter></Fill>
                                                       <Stroke><CssParameter name="stroke">#000000</CssParameter>
        <CssParameter name="stroke-opacity">0</CssParameter><CssParameter name="stroke-width">0</CssParameter>
                                                  </Stroke>
                                       </Mark>
                                       <Size>20</Size>
                               </Graphic>
                               </PointSymbolizer>
                           </Rule>
                       </FeatureTypeStyle>
                       </UserStyle>
                   </NamedLayer>
           </SLD>
       </Style>
   </StyleList>
</Layer>
Saul Farber wrote:
Josh,
Here's an example that works just fine for us (modified mapbuilder 1.0_rc2)
--saul
<Layer queryable="1" hidden="1">
      <Server service="OGC:WMS" version="1.1.1" title="Local">
        <OnlineResource xlink:type="simple" xlink:href="http://64.119.128.70/geoserver/wms&quot;/&gt;
      </Server>
      <Name>GISDATA.TOWNS_POLY</Name>
      <Title>MA Town Labels</Title>
      <SRS>EPSG:26986</SRS>
      <FormatList>
      </FormatList>
      <StyleList>
        <Style current="1">
          <SLD>
            <StyledLayerDescriptor version="1.0.0">
              <NamedLayer>
                <Name>massgis:GISDATA.TOWNS_POLY</Name>
                <UserStyle>
                  <FeatureTypeStyle>
                    <Rule>
                      <TextSymbolizer>
                        <Label>
                          <PropertyName>TOWN</PropertyName>
                        </Label>
                        <Font>
                          <CssParameter name="font-family">Arial</CssParameter>
                        </Font>
                        <Fill>
                          <CssParameter name="fill-opacity">0.5</CssParameter>
                        </Fill>
                      </TextSymbolizer>
                    </Rule>
                  </FeatureTypeStyle>
                </UserStyle>
              </NamedLayer>
          </SLD>
        </Style>
      </StyleList>
    </Layer>
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Mapbuilder-users mailing list
Mapbuilder-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/mapbuilder-users
I 'm sure PropertyName is good because when i send the contain of <sld> to a get map request it works correctly and Type property appears.
Is it possible you try this WMC on your geoserver ?
Like this i would known if it is my envirronement who bug
Brent Owens
hi,
     <General>
           <KeywordList>
           </KeywordList>
   </General>
       <LayerList>
               </Server>
               <FormatList>
               </FormatList>
                   <SLD>
                           <NamedLayer>
                               <UserStyle>
                                   <Title/>
                                   <Abstract/>
                                   <FeatureTypeStyle>
                                       <Rule>
                                           <LineSymbolizer>
                                               <Stroke>
                                               </Stroke>
                                           </LineSymbolizer>
                                       </Rule>
                                       <Rule>
                                           <TextSymbolizer>
                                               <Label>
                                               </Label>
                                               <Font>
                                               </Font>
                                               <Halo>
                                                   <Radius>2</Radius>
                                                   <Fill>
                                                   </Fill>
                                               </Halo>
                                               <Fill>
                                               </Fill>
                                       </TextSymbolizer>
                                   </Rule>
                           </FeatureTypeStyle>
                     </UserStyle>
               </NamedLayer>
</ViewContext>
Brent Owens
hi,
Thanks in advance.
</Server>
<FormatList>
</FormatList>
<StyleList>
   <Style current="1">
       <SLD>
               <NamedLayer>
                       <Abstract/>
                               <PointSymbolizer>
                               <Graphic>
                                       <Mark>
                                                  </Stroke>
                                       </Mark>
                                       <Size>20</Size>
                               </Graphic>
                               </PointSymbolizer>
                           </Rule>
                       </FeatureTypeStyle>
                       </UserStyle>
                   </NamedLayer>
           </SLD>
       </Style>
   </StyleList>
</Layer>
Saul Farber wrote:
Josh,
--saul
      </Server>
      <FormatList>
      </FormatList>
      <StyleList>
        <Style current="1">
          <SLD>
              <NamedLayer>
                <UserStyle>
                  <FeatureTypeStyle>
                    <Rule>
                      <TextSymbolizer>
                        <Label>
                        </Label>
                        <Font>
                        </Font>
                        <Fill>
                        </Fill>
                      </TextSymbolizer>
                    </Rule>
                  </FeatureTypeStyle>
                </UserStyle>
              </NamedLayer>
          </SLD>
        </Style>
      </StyleList>
    </Layer>
