[Geoserver-users] [Re: OGC OpenLS Implementation?]
Hi David, geoserver-users,
Yes, Andrew Hughes did an excellent job implementing the OpenLS spec and Lisasoft would like to roll it into Geoserver.
We are just looking for a paid project or similar which will justify our developer's time supporting and migrating the code. I'm open to suggestions.
Stefan Hansen wrote:
Hey Cameron!
You've probably seen this mail anyway and I'm not too sure of how much interest this could be for LISAsoft, but well maybe it is and maybe you have overlooked it. This is Azza's response to an mail to the Geoserver mailing list:
-------- Original Message --------
Subject: Re: [Geoserver-users] OGC OpenLS Implementation?
Date: Fri, 24 Aug 2007 09:54:52 +0930
To: David R Robison <drrobison@anonymised.com>
CC: geoserver-users@lists.sourceforge.net
References: <20070816143603.3de5cdaf@anonymised.com> <46C5454E.5060103@anonymised.com> <97045D76-FBD0-4AEC-9461-F7478F923D52@anonymised.com> <46CDAC2C.3020904@anonymised.com>
Hi David,
I wrote a (Java5+) API for the complete OLS 1.1 spec when I was working for LISAsoft/TerraPages.
http://terrapages.net/opengis-api/
It works excellent, is very simple to use, its fast and it is the complete OLS spec! I can no longer speak on behalf of the company but if nothing has changed, then it is not 'officially' opensourced because no one has adopted it for one reason....
This is the complete OLS spec nothing less and nothing MORE. Specifically if you want to add your own custom content (xml element or attibute), this " Extensibile" functionality is not provided. There is merit to such a requirement but it is also additional complexity that is holding up what would otherwise be an easy (and now working) service implementation.
And FYI: I also co-wrote the service implementations, and clients that use these services. It's amazing how much value you can get out of this specification when its so easy to use!
https://terrapages.net/opengis-xls/
Anyway, the LISAsoft boys are working pretty closely with Geoserver these days and they should notice this thread.
--Over and out
On 8/24/07, *David R Robison* <drrobison@anonymised.com <mailto:drrobison@anonymised.com>> wrote:
   Has any thought been given to developing an OGC Open Location Service
   (OpenLS) service for geoserver? Does anyone know of an open source
   implementation of the OpenLS service?
   Thanks, David Robison
   David R Robison
   Open Roads Consulting, Inc.
   708 S. Battlefield Blvd., Chesapeake, VA 23322
   phone: (757) 546-3401
   e-mail: drrobison@anonymised.com
   web: http://openroadsconsulting.com
   blog: http://therobe.blogspot.com
   book: http://www.xulonpress.com/book_detail.php?id=2579
   Geoserver-users mailing list
   <mailto:Geoserver-users@lists.sourceforge.net>
   <https://lists.sourceforge.net/lists/listinfo/geoserver-users&gt;
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
One of the things I would like to do with OpenLS is to set it up to allow the client to send a roadway location (Interstate, direction, milepost) and have the service return the Lat/Lon. We do this now using roadway data provided by our state DOT, but am interested in providing a standards based approach to doing this geocoding. Is this possible with OpenLS? What are the data requirements to us the Lisasoft software to do geocoding? While I cannot make commitments for my company, there may be some interest in paying for part of the transition to Open Source.
Thanks in advance, David
From: Cameron Shorter [mailto:cameron.shorter@anonymised.com]
To: David R Robison [mailto:drrobison@anonymised.com410…], geoserver-users@lists.sourceforge.net
Sent: Fri, 24 Aug 2007 03:31:12 -0400
Subject: Re: [Geoserver-users] [Fwd: Re: OGC OpenLS Implementation?]
developer’s time supporting and migrating the code. I’m open to
suggestions.
Hey Cameron!
You’ve probably seen this mail anyway and I’m not too sure of how much
you have overlooked it. This is Azza’s response to an mail to the
<46C5454E.5060103@anonymised.com…>
<46CDAC2C.3020904@anonymised.com410…>
Hi David,
if nothing has changed, then it is not ‘officially’ opensourced
because no one has adopted it for one reason…
use these services. It’s amazing how much value you can get out of
–Over and out
On 8/24/07, David R Robison <drrobison@anonymised.com
David R Robison
mailto:[drrobison@anonymised.com..](mailto:drrobison@anonymised.com)
browser.
mailto:[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
<https://lists.sourceforge.net/lists/listinfo/geoserver-users>
Cameron Shorter
Has any more thought been given to this idea? Any thought on how much of a "paid project" it would take to integrate this into geoserver? Thanks, David Robison
Hey Cameron!
Hi David,
--Over and out
   David R Robison
David R Robison
