[Geoserver-users] RE: <ogc:Touches> tag
Hmmm... I've never seen that error. Could you turn on Config -> Server -> Verbose Exceptions and set the log level to FINE? And send me the logs of the request and the error you get?
And what datastore are you using? I think the problem might be that the backend request isn't getting the geometry to do the filtering against. I thought we'd fix it to deal with such things. And actually I just tested this against shapefile and it worked fine. What version of GeoServer are you using?
Chris
Chris Holmes wrote:
Lee Wai See wrote:
Hi Chris,
Thanks to your suggestion, I tried the following WFS request:
<wfs:GetFeature service="WFS" version="1.0.0"
  outputFormat="GML2"
  xmlns:prrm="http://www.openplans.org/prrm&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:gml="http://www.opengis.net/gml&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
                      http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
  <wfs:Query typeName="prrm:road">
    <wfs:PropertyName>prrm:road_name</wfs:PropertyName>
    <ogc:Filter>
      <ogc:DWithin>
        <ogc:PropertyName>the_geom</ogc:PropertyName>
        <gml:Point
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;&lt;gml:coordinates&gt;103\.
86225677490186,1.301676523353803</gml:coordinates>
        </gml:Point>
        <Distance unit="m">0.00001</Distance>
      </ogc:DWithin>
   </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
However, I got this exception when the request is submitted:
<?xml version="1.0" ?> <ServiceExceptionReport version="1.2.0" xmlns="http://www.opengis.net/ogc&quot;
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost:8080/geoserver/data/capabilities//wfs/1.0.0/OGC-
exception.xsd">
      <ServiceException>java.lang.IllegalArgumentException: FeatureReader
allready produces contents with the correct schema</ServiceException> </ServiceExceptionReport>
As you can see, what I am trying to do filter out all the name of the roads
within certain distance from the given point with the line
<wfs:PropertyName>prrm:road_name</wfs:PropertyName>. But if I remove this
line, the request works but returns me all the properties of the features.
Thus, my question is, can I just filter out the name of the features for a
DWithin filter? I have tested filtering out certain properties of features
in a same manner with tags such as Intersects and I thought it should be
possible too for DWithin. If it is possible, then any idea what should be
the right way of doing it?
Would appreciate a lot for your reply. Thanks.
Regards, Lee Wai See ST Electronics (Info-Software Systems) Pte Ltd
-----Original Message-----
From: Chris Holmes [mailto:cholmes@anonymised.com] Sent: Thursday, May 25, 2006 12:11 AM
To: Lee Wai See
Subject: Re: [Geoserver-users] RE: <ogc:Touches> tag
The OGC filter specification: http://portal.opengeospatial.org/files/?artifact_id=8340
The filter is called DWithin. You put in the geometry and the distance that should match.
Lee Wai See wrote:
Hi Chris,
Thanks for replying.
You also could do a distance filter with a small amount of give, which would give you some margin for if the point isn't precisely touching.
How can I go about doing this? Is there any reference for me? Thank you.
[mailto:geoserver-users-admin@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Wednesday, May 24, 2006 1:36 AM
To: Lee Wai See
Apologies for missing this earlier.
Yes, the touches tag is supported.
I'm pretty positive that result means nothing was returned.
Note that touches is super exact, you may try using intersects. I'm not sure if it's actually different for points, but it may get you better results. You also could do a distance filter with a small amount of give, which would give you some margin for if the point isn't precisely touching.
Chris
Lee Wai See wrote:
Could anyone kindly help me on this below (as sent to the list
previously)?
Once again, thank you very much.
_____ From: Lee Wai See [mailto:leewse@anonymised.com] Sent: Wednesday, May 17, 2006 2:35 PM
To: 'geoserver-users@lists.sourceforge.net'
Subject: <ogc:Touches> tag
I am wondering whether the <ogc:Touches> tag is supported by GeoServer. I
have been trying to use this tag to filter out some features that touches
a
given point. My query is as such:
  <ogc:Filter>
    <ogc:Touches>
      <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;
         <gml:coordinates>103.82110722,1.38459521</gml:coordinates>
      </gml:Point>
    </ogc:Touches>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
This is the result I got after submitting the request to the server:
<gml:boundedBy>
<gml:null>unknown</gml:null>
</gml:boundedBy>
I am wondering what this means. Does it mean that there is no feature that
the point touches, or is there an error in my request? If the problem lies
with my request, please tell me where I went wrong and how I should
construct a correct one. Would really appreciate if someone could give me
some pointers. Thank you.
[This e-mail is confidential and may be priviledged. If you are not the
intended recipient, please kindly notify us immediately and delete the
message
from your system; please do not copy or use it for any purpose, nor
disclose
its contents to any other person. Thank you.]
---ST Electronics Group---
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Hi Chris,
Thanks for the reply.
I have set the log level to FINE and please find attached a copy of the logs
of the request and error. If you need more logs information, please let me
know.
PostgreSQL 8.0
GeoServer 1.3.0-RC2
Lee Wai See
Holmes
Sent: Wednesday, May 31, 2006 12:49 AM
To: Lee Wai See
Chris
Chris Holmes wrote:
Lee Wai See wrote:
Hi Chris,
  outputFormat="GML2"
    <ogc:Filter>
      <ogc:DWithin>
        <gml:Point
        </gml:Point>
      </ogc:DWithin>
   </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
exception.xsd">
roads
features.
for a
features
25, 2006 12:11 AM
To: Lee Wai See
Lee Wai See wrote:
Hi Chris,
touching.
Holmes
To: Lee Wai See
Chris
Lee Wai See wrote:
previously)?
_____
GeoServer. I
touches
a
  <ogc:Filter>
    <ogc:Touches>
      <gml:Point
      </gml:Point>
    </ogc:Touches>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
<gml:boundedBy>
</gml:boundedBy>
feature that
problem lies
give me
message
disclose
Chris Holmes
logs.log (14.7 KB)
Could you upgrade to 1.3.0 and see if that fixes your problems? There's a decent chance your bug was just fixed, and if not it's much easier for us to debug right.
best regards,
Chris
Lee Wai See wrote:
Hi Chris,
know.
PostgreSQL 8.0
GeoServer 1.3.0-RC2
Holmes
To: Lee Wai See
Chris
Chris Holmes wrote:
Lee Wai See wrote:
Hi Chris,
outputFormat="GML2"
   <ogc:Filter>
     <ogc:DWithin>
       <gml:Point
       </gml:Point>
     </ogc:DWithin>
  </ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
exception.xsd">
To: Lee Wai See
Lee Wai See wrote:
Hi Chris,
Holmes
To: Lee Wai See
Chris
Lee Wai See wrote:
previously)?
a
<ogc:Filter>
   <ogc:Touches>
     </gml:Point>
   </ogc:Touches>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
<gml:boundedBy>
</gml:boundedBy>
message
disclose
Chris Holmes
