[Geoserver-users] re: opaque="1"
Another question.
Is it possible to set the WMS opaque=“1” true in Geoserver?
I would think since the Geoserver datastores are vector this could be done for image/png
It would be useful for overlaying disparate WMS sources. This is only because there are so few WFS sites currently. So far I have not run across any WMS that actually had an opaque=”1” attribute.
I guess the WFS cascade supercedes this by letting a Geoserver WFS become a datastore in its own right. If I understand how this would work a Geoserver WFS could be set up with a featuretype, then a datastore could be added that uses this WFS featuretype, which in turn could then be styled and rendered over WMS.
As far as interoperability, cascades are actually better, but I had a client wonder about adding multiple WMS layers together from multiple sources. The only way I could see to do this now, is to take say a USGS Atlas layer as image/jpeg and using server side JAI convert background pixels to alpha 00 – perhaps #FFFFFF pixels to #FFFFFF00 which are then exported as image/png (a potentially evil server side resource hog). This way at least disparate WMS layers could be overlaid.
However is there a better approach?
rkgeorge
I don't think you would really want to set opaque=1, and doing so doesn't really have much to do with cascading. When we have raster support I imagine we may make opaque=1 for those layers, but basically it should be set when the majority of the image is covered, which is generally not the case in vector data.
I think what you're looking for is the 'transparent' parameter for a GetMap request. From the WMS 1.1.1 spec:
'When TRANSPARENT is set to TRUE and the FORMAT parameter contains a Picture
format (e.g., image/gif), then a WMS shall return (when permitted by the requested
format) a result where all of the pixels not representing features or data values in that
Layer are set to a transparent value. For example, a "roads" layer would be transparent
wherever no road is shown. When TRANSPARENT is set to FALSE, those pixels shall
be set to the value of BGCOLOR (Section 7.2.3.10).
When the Layer has been declared as "opaque" as in Section 7.1.4.6.3, then significant
portions, or the entirety, of the map may not be able to made transparent.'
I think this is the general approach for overlaying WMS images on top of one another, indeed doing that is exactly what the WMS spec was designed for... I believe on the backend it's telling servers to do exactly what you are suggesting. I think most WMS servers do accept that parameter.
best regards,
Chris
Randy George wrote:
            Another question.
            Is it possible to set the WMS opaque="1" true in Geoserver?
any WMS that actually had an opaque="1" attribute.
over WMS.
image/jpeg and using server side JAI convert background pixels to alpha 00 -
rkgeorge
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
Great! Thanks for the help.
rkgeorge
-----Original Message-----
[mailto:geoserver-users-admin@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: Friday, February 24, 2006 12:30 PM
To: Randy George
Subject: Re: [Geoserver-users] re: opaque="1"
requested
data values in that
be transparent
pixels shall
then significant
best regards,
Chris
Randy George wrote:
            Another question.
a
Geoserver
that
over WMS.
client
The
(a
WMS
rkgeorge
Chris Holmes
