[Geoserver-users] [Re: Problem with OWS GeoServer 2.2.2]
Hi, dear all,
I've got the GS Version 2.2
i have got not the same problem: but it is:
I have a problem for publishing map in the section of the
tutorial:"GeoServer 2.2.x User Manual » Getting Started » Publishing a
Shapefile"
http://docs.geoserver.org/stable/en/user/gettingstarted/shapefile-quickstart/index.html
with the weblink "openlayers" and the example nyc-roads there is
no map inside the openlayers environment.
And it is the same result for all example inside this tutorial.
however, I can display all map via wms or wfs services in all formats
jpeg, png etc.
Does anyone can help me about this problem of displaying map with this
openlayers links!
Thank you
Anne Q
Hello all,
I tried the new version of GS 2.2.2, but I have major problems with
publishing / querying layers... Here is the thing :
- i made a copy of my data_dir (working well with GS 2.2.0)
- i installed GS 2.2.2
- i put the new data_dir directory, next to the default data directory
As long as I work with the default data, with default GEOSERVER_DATA_DIR
path in the WEB-INF/web.xml (I'm using Tomcat 7), there is no problem.
If I change the GEOSERVER_DATA_DIR to my own data_dir, the web interface
seems to work well, but major problems are :
- WMS queries send 404 error with all layer previews
/*HTTP Status 404 -*
type Status report
message
description The requested resource () is not available./
- even if I add a new resources, the new layers still has the sam error
If I go to the log, here is the first error :
2012-12-05 12:10:13,230 DEBUG
[org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] -
httpMethods[0]: POST
httpMethods[1]: DELETE
httpMethods[2]: PUT
2012-12-05 12:11:12,860 DEBUG [org.geoserver.security] - Start searching
for expired authentication tokens
2012-12-05 12:11:12,862 DEBUG [org.geoserver.security] - Number of
expired authentication tokens found: 0
2012-12-05 12:11:12,862 DEBUG [org.geoserver.security] - End searching
2012-12-05 12:12:12,860 DEBUG [org.geoserver.security] - Start searching
2012-12-05 12:12:12,861 DEBUG [org.geoserver.security] - Number of
2012-12-05 12:12:12,861 DEBUG [org.geoserver.security] - End searching
2012-12-05 12:12:45,641 TRACE [org.geoserver.ows.OWSHandlerMapping] - No
handler mapping found for [/web/]
2012-12-05 12:12:45,644 TRACE [org.geoserver.ows.OWSHandlerMapping] - No
2012-12-05 12:12:45,645 TRACE [org.geoserver.ows.OWSHandlerMapping] - No
2012-12-05 12:12:45,730 DEBUG [org.geoserver] - Thread 41 locking in
mode READ
2012-12-05 12:12:45,731 DEBUG [org.geoserver] - Thread 41 got the lock
in mode READ
2012-12-05 12:12:46,053 DEBUG [org.geoserver.security] - Les créances
sont erronées
org.springframework.security.authentication.BadCredentialsException: Les
créances sont erronées
         at
org.springframework.security.authentication.dao.DaoAuthenticationProvider.additionalAuthenticationChecks(DaoAuthenticationProvider.java:67)
         at
org.springframework.security.authentication.dao.AbstractUserDetailsAuthenticationProvider.authenticate(AbstractUserDetailsAuthenticationProvider.java:149)
2012-12-05 12:12:46,254 INFO [org.geoserver.security] - Strong
cryptograhpy is available
2012-12-05 12:12:46,538 DEBUG [org.geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.2.jar!/org/geoserver/web/GeoServerHomePage.html
to file (URI is not hierarchical), falling back to the inputstream for
polling
2012-12-05 12:12:46,583 DEBUG [org.geoserver.web] - cannot convert url:
jar:file:/var/lib/tomcat7/webapps/geoserver/WEB-INF/lib/web-core-2.2.2.jar!/org/geoserver/web/GeoServerBasePage.html
polling
... and it goes on with many errors.
Does anyone have the same problem with services ?
Thank you,
Gabriel Vatin
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d_______________________________________________
Geoserver-users mailing list
Quesnel Anne - Dr en Géographie quantitative; Géomatique en Santé.
http://quesnela.free.fr/
Adresse physique
CHRU de Lille,
Pôle de Santé Publique.
Unité de Conseils Méthodologiques: Dr A Duhamel
Coordinateur du pôle: Pr Beuscart Régis.
Adresse Postale:
Anne Quesnel
CHRU de Lille,
SEDAF - Parc Eurasanté
Bâtiment Hippocrate
154 rue du Dr Yersin
59037 Lille cedex
Tel en interne poste 36100
Secrétariat jusque 16h : 03 20 44 55 18
Après 16h : 03 20 44 59 62 poste 36100
Fax : 03 20 44 69 45
