[Geoserver-users] Rebuild GWC
Hello,
this time just a simple question:
how can I *force* gwc to rebuild *all* layers?
best regards
HZN
Hi Hartmut,
3 methods.
1. sledgehammer approach: delete or rename the layers
2. via interface: 'demo' page --> 'Seed this layer' ---> 'Type of operation'
select 'Reseed - regenerate all tiles'
3. Let the user do it: expire them using the geowebcache.xml
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department Environment and Primary Industries
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rebuild-GWC-tp5093241p5093274.html
Hello Christian.
Am 09.12.2013 02:25, schrieb cmaul:
Hi Hartmut,
3 methods.
I am sure, that would work but doing it for about 200 Layers....
operation' select 'Reseed - regenerate all tiles'
Thanks a lot for that hint, I did not see that option (only tried
"Seed - generate missing tiles".
But still it does not work, the preview still shows the symbols for
broken images...
Cant seem to find that file in webapps/geoserver.
Anyway would it be safe to wipe geoserver/data/gwc-layers ? And then
re-enable caching for the given 200 layers ....
Guess, I have to read more friendly manuals :wink:
Christian
----- ____________________________
Dr Christian Maul Project Manager
Information Services Branch Department Environment and Primary
Industries Level13, Marland House, 570 Bourke Street Melbourne
3000
Telephone: +61-3-8636 2325 Telefax: +61-3-8636
2813 -- View this message in context:
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code
base. Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-users mailing list Geoserver-users@lists.sourceforge.net
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
  1. via interface: ‘demo’ page → ‘Seed this layer’ —> ‘Type of
    operation’ select ‘Reseed - regenerate all tiles’
“Seed - generate missing tiles”.
broken images…
Maybe your problem isn’t that the tiles need reseeding then. You shouldn’t be getting the “broken images” tile. Re-seeding only needs to be done when the old tiles are out of date. If the service wasn’t working in the first place re-seeding is unlikely to solve anything.
Does/did the service work before reseeding?
Jonathan
