Saul,
I have a ArcSDE layer called SDE.DAVE_TEST with the following schema:
DETAILS: string
SHAPE: pointProperty
SHAPE.FID int
I can insert data into the layer using the ArcSDE MOJE APIs. I would
like to insert data using WFS-T. I can successfully execute WFS-T
deletes on date that exists in the ArcSDE Layer but I am unable to
execute WFS-T inserts and updates. Below is the Insert Transaction that
is causing the ArrayIndexOutOfBoundException:
<wfs:Transaction service="WFS" version="1.0.0"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:c2wfs="http://schemas.c2.ngc.com/wfs/2006/01/MIL-STD-2525B"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd
http://localhost:8080/geoserver/wfs/DescribeFeatureType?typename=SDE.DAV
E_TEST">
<wfs:Insert>
<c2wfs:SDE.DAVE_TEST>
<c2wfs:ID>5CBE92E0-42E7-9999-1133-123456789WFS</c2wfs:ID>
<c2wfs:SHAPE>
<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#0">
<gml:coordinates xmlns:gml="http://www.opengis.net/gml" decimal="."
cs="," ts="">-53.25887996,-26.23749992</gml:coordinates>
</gml:Point>
</c2wfs:SHAPE>
</c2wfs:SDE.DAVE_TEST>
</wfs:Insert>
</wfs:Transaction>
Here is the stacktrace from the insert transaction:
May 7, 2007 4:58:41 PM
org.vfny.geoserver.wfs.responses.TransactionResponse execute
FINE: Locating FeatureSource
uri:'http://schemas.c2.ngc.com/wfs/2006/01/MIL-STD-2525B’
FINE: located FeatureType w/ typeRef 'ArcSDEDataStore:SDE.DAVE_TEST' and
elementName 'c2wfs:SDE.DAVE_TEST'
FINER: Transasction Insert:Handle: null SDE.DAVE_TEST 1
ReleaseAll: false
TypeName: c2wfs:SDE.DAVE_TEST
Feature[ id=fid-767534a_11267322963__7feb ,
ID=5CBE92E0-42E7-9999-1133-123456789WFS , DETAILS=null , SHAPE=POINT
(-53.25887996 -26.23749992) , SHAPE.FID=null ]
May 7, 2007 4:58:41 PM org.vfny.geoserver.global.Data getFeatureTypeInfo
FINE: getting type c2wfs:SDE.DAVE_TEST
FINER: Use featureValidation to check contents of insert
org.vfny.geoserver.wfs.responses.TransactionResponse featureValidation
FINER: FeatureValidation called on ArcSDEDataStore:SDE.DAVE_TEST
org.geotools.data.arcsde.ArcSDEConnectionPool$SeConnectionFactory
activateObject
FINEST: activating connection
org.geotools.data.arcsde.PooledConnection@anonymised.com
May 7, 2007 4:58:42 PM
activateObject
activateObject
activateObject
activateObject
May 7, 2007 4:58:42 PM org.geotools.data.arcsde.ArcSDEAdapter
createAttributeTypes
WARNING: No Row-ID Column registered on table 'SDE.DAVE_TEST', using
SE_SAHPE_ATTRIBUTE_FID value 'SHAPE.FID'
May 7, 2007 4:58:42 PM org.geotools.data.arcsde.ArcSDEAdapter parseCRS
INFO: About to parse CRS for layer DAVE_TEST:
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",63w.opengis
.net/wfs Insert wfs:Insert
org.vfny.geoserver.wfs.requests.TransactionFeatureHandler
handleCharacters
FINE: we are inside attribute: false, curAttType is DefaultAttributeType
[name=SHAPE , type=class com.vividsolutions.jts.geom.Point ,
nillable=false, min=1, max=1] curFeatureT: DefaultFeatureType
[name=SDE.DAVE_TEST ,
namespace=http://schemas.c2.ngc.com/wfs/2006/01/MIL-STD-2525B ,
abstract=false ,
types=(org.geotools.data.arcsde.ArcSDEAttributeType@anonymised.com,org.geotools
.data.arcsde.ArcSDEAttributeType@anonymised.com,DefaultAttributeType
max=1],org.geotools.data.arcsde.ArcSDEAttributeType@anonymised.com,)] attName
May 7, 2007 4:58:41 PM org.geotools.filter.FilterFilter endElement
FINER: found end element: Insert
processCharacters
FINER: delegating characters to parent:
org.vfny.geoserver.wfs.requests.TransactionHandler endElement
FINER: at end element: Insert
May 7, 2007 4:58:41 PM org.vfny.geoserver.wfs.requests.InsertRequest
addFeature
INFO: got type
SDE.DAVE_TEST,http://schemas.c2.ngc.com/wfs/2006/01/MIL-STD-2525B
org.vfny.geoserver.wfs.requests.TransactionFeatureHandler endElement
FINEST: end - inside feature
May 7, 2007 4:58:41 PM GMLFilterDocument endElement
FINER: RETURN
May 7, 2007 4:58:41 PM GMLFilterDocument characters
FINER: ENTRY [C@anonymised.com 759 1
FINER: RETURN
FINER: ENTRY http://www.opengis.net/wfs Transaction wfs:Transaction
handleCharacters
abstract=false ,
FINER: found end element: Transaction
processCharacters
FINER: at end element: Transaction
FINER: RETURN
org.vfny.geoserver.wfs.requests.readers.TransactionXmlReader read
FINER: just parsed: org.xml.sax.InputSource@anonymised.com
May 7, 2007 4:58:41 PM org.vfny.geoserver.servlets.AbstractService
doService
INFO: handling request: Lock Id: null
releaseAction: ALL
handle: null
ReleaseAll: false
TypeName: SDE.DAVE_TEST
doService
FINE: strategy is: FILE
doService
FINER: executing request
FINE: request is Lock Id: null
releaseAction: ALL
handle: null
ReleaseAll: false
ReleaseAll: false
activateObject
activateObject
activateObject
activateObject
activateObject
GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,2
98.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]
INFO: Se CRS envelope:
(-180.000000167638,-90.0000001676381,179.9999998323621,269.999999832362)
FINE: ArcSDE CRS correctly parsed from layer DAVE_TEST
FINE: Using arcsde 9 methods
May 7, 2007 4:58:42 PM org.geotools.data.arcsde.ArcSDEFeatureWriter
write
WARNING: 3
java.lang.ArrayIndexOutOfBoundsException: 3
at
org.geotools.data.arcsde.ArcSDEFeatureWriter.getColumns(ArcSDEFeatureWri
ter.java:382)
at
org.geotools.data.arcsde.ArcSDEFeatureWriter.write(ArcSDEFeatureWriter.j
ava:265)
at
org.geotools.data.AbstractFeatureStore.addFeatures(AbstractFeatureStore.
java:226)
at
org.vfny.geoserver.global.GeoServerFeatureStore.addFeatures(GeoServerFea
tureStore.java:78)
at
org.vfny.geoserver.wfs.responses.TransactionResponse.execute(Transaction
Response.java:425)
at
Response.java:115)
at
org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.ja
va:516)
at
org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:
447)
at org.geoserver.request.Dispatcher.post(Dispatcher.java:295)
at
org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:181)
at
org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:5
2)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(Abs
tractController.java:139)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handl
e(SimpleControllerHandlerAdapter.java:44)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherS
ervlet.java:684)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherSe
rvlet.java:625)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(Framewor
kServlet.java:392)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet
.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHan
dler.java:1050)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharac
terEncodingFilter.java:103)
at
dler.java:1041)
at
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
at
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
at
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
at
org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandler
Collection.java:149)
at
org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.jav
a:123)
at
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:269)
at
org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
at
org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.j
ava:701)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:617)
at
org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:193)
at
org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
at
org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:2
70)
at
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.ja
va:475)
May 7, 2007 4:58:42 PM org.vfny.geoserver.ServiceException <init>
FINE: org.geotools.data.DataSourceException: 3
May 7, 2007 4:58:42 PM org.vfny.geoserver.servlets.AbstractService
doService
WARNING: service exception while executing request: Lock Id: null
releaseAction: ALL
handle: null
ReleaseAll: false
cause: org.geotools.data.DataSourceException: 3
sendError
SEVERE: Service exception occurred
org.vfny.geoserver.wfs.responses.WfsTransactionException:
at
Response.java:432)
at
Response.java:115)
at
va:516)
at
447)
at
at
2)
at
at
at
ervlet.java:684)
at
rvlet.java:625)
at
kServlet.java:392)
at
.java:357)
at
at
dler.java:1050)
at
at
dler.java:1041)
at
at
at
at
at
a:123)
at
at
at
ava:701)
at
at
at
70)
at
va:475)
Caused by: org.geotools.data.DataSourceException: 3
at
ava:314)
at
java:226)
at
tureStore.java:78)
at
Response.java:425)
... 32 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 3
at
ter.java:382)
at
ava:265)
... 35 more
getXmlResponse
WARNING: encountered error: org.geotools.data.DataSourceException: 3
StackTrace: org.geotools.data.DataSourceException: 3
at
ava:314)
at
java:226)
at
tureStore.java:78)
at
Response.java:425)
at
Response.java:115)
at
va:516)
at
447)
at
at
2)
at
at
at
ervlet.java:684)
at
rvlet.java:625)
at
kServlet.java:392)
at
.java:357)
at
at
org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletH78
137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925
199433]]
write
WARNING: 3
at
ter.java:382)
at
ava:265)
at
java:226)
at
tureStore.java:78)
at
Response.java:425)
at
Response.java:115)
at
va:516)
at
447)
at
at
2)
at
at
at
ervlet.java:684)
at
rvlet.java:625)
at
kServlet.java:392)
at
.java:357)
at
at
dler.java:1050)
at
at
dler.java:1041)
at
at
at
at
at
a:123)
at
at
at
ava:701)
at
at
at
70)
at
va:475)
doService
releaseAction: ALL
handle: null
ReleaseAll: false
sendError
at
Response.java:432)
at
Response.java:115)
at
va:516)
at
447)
at
at
2)
at
at
at
ervlet.java:684)
at
rvlet.java:625)
at
kServlet.java:392)
at
.java:357)
at
at
dler.java:1050)
at
at
dler.java:1041)
at
at
at
at
at
a:123)
at
at
at
ava:701)
at
at
at
70)
at
va:475)
at
ava:314)
at
java:226)
at
tureStore.java:78)
at
Response.java:425)
... 32 more
at
ter.java:382)
at
ava:265)
... 35 more
getXmlResponse
at org.geotools.data.arcsde.ArcSDEFeatureWriandler.java:1050)
at
at
dler.java:1041)
at
at
at
at
at
a:123)
at
at
at
ava:701)
at
at
at
70)
at
va:475)
at
ter.java:382)
at
ava:265)
... 35 more
getXmlResponse
FINE: return wfs exception is <?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost:8080/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
org.geotools.data.DataSourceException: 3 </ServiceException>
</ServiceExceptionReport>
ter.write(ArcSDEFeatureWriter.java:314)
at
java:226)
at
tureStore.java:78)
at
Response.java:425)
at
Response.java:115)
at
va:516)
at
447)
at
at
2)
at
at
at
ervlet.java:684)
at
rvlet.java:625)
at
kServlet.java:392)
at
.java:357)
at
at
dler.java:1050)
at
at
dler.java:1041)
at
at
at
at
at
a:123)
at
at
at
ava:701)
at
at
at
70)
at
va:475)
at
ter.java:382)
at
ava:265)
... 35 more
getXmlResponse
version="1.2.0"
<ServiceException>
Thanks so much for taking a look at this.
Dave
-----Original Message-----
From: Farber, Saul (ENV) [mailto:Saul.Farber@anonymised.com]
Sent: Monday, May 07, 2007 3:08 PM
To: Plewes, David J.; Andrea Aime
Subject: RE: [Geoserver-users] Receive java.lang.StackOverflowError
withInsert transaction
Dave,
Do you have a stack trace from the geoserver output console? It would
help much in trying to figure out exactly what's going wrong.
I'm not 100% sure, but from the request that you're sending, it looks
like you're not actually inserting any values into the table. Just that
you're trying to insert a feature with no attributes set at all. I can
imagine that this might not work correctly...can you try inserting a
feature with values? The feature values will need to be set correctly
for the feature type, etc.
--saul
From: geoserver-users-bounces@lists.sourceforge.net on behalf of Plewes,
David J.
Sent: Mon 5/7/2007 2:55 PM
To: Andrea Aime
Subject: Re: [Geoserver-users] Receive java.lang.StackOverflowError
Andrea,
Thanks for your help. I installed GeoServer 1.5.0 along with the latest
ArcSDE plugin.
I configured the DataStore and NameSpace and I can successfully query
data using WFS.
Also, I can get the following Delete Transaction to work where the
Filter selected the Feature with an "ID":
<wfs:Transaction service="WFS" version="1.0.0" outputFormat="GML2"
xmlns:ogc="http://www.opengis.net/ogc"
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Delete typeName="c2wfs:SDE.DAVE_NODELETE">
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>ID</ogc:PropertyName>
<ogc:Literal>5CBE92E0-42E7-9999-1133-DAVE</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
</wfs:Delete>
</wfs:Transaction>
Here is a Insert that I am trying:
E_NODELETE">
<wfs:Insert>
<c2wfs:SDE.DAVE_NODELETE>
</c2wfs:SDE.DAVE_NODELETE>
</wfs:Insert>
</wfs:Transaction>
But, Insert and Update do not work. I receive an
ArrayIndexOutOfBoundsException followed by a number.
The number is the number of columns in the ArcSDE layer (table). I
tried different tables and determined that the returned number is the
number of columns. The DescribeFeattureType works properly so I am not
sure where the problem is. Am I missing a configuration of the schema?
Dave
Sent: Monday, May 07, 2007 3:41 AM
Subject: Re: [Geoserver-users] Receive java.lang.StackOverflowError with
Insert transaction
Plewes, David J. ha scritto:
Hi list,
I am currently using Geoserver version 1.3.0 with ArcSDE 9.0. I have
no problems with the WFS GetFeature requests using this combination of
Geoserver/ArcSDE. But, when I try WFS-T Insert I receive a
java.lang.StackOverflowError. I have tried adding increasing the
stack size to 1024k with "-Xss1024k" when Geoserver is started.
Below is the WFS-T Insert Transaction:
_http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd_
_http://arcsde.c2f.northgrum.com:8090/geoserver/wfs/DescribeFeatureTyp
e?typename=SDE.DAVE_TEST_">
<wfs:Insert>
</wfs:Insert>
</wfs:Transaction>
This is a very simple insert. I have tried inserts with more elements
but still get the same result.
Attached is the geoserver.log file with a log level of ALL. I am
beginning to think that I need a higher version of Geoserver and maybe
a higher version of ArcSDE.
For sure Geoserver 1.3.0 is too old. Geoserver 1.5.0 is the latest
version, and has quite some ArcSDE changes in it.
I'd suggest to try it out and let us know.
This SF.net email is sponsored by DB2 Express Download DB2 Express C -
the FREE version of DB2 express and take control of your XML. No limits.
Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-users mailing list
