Jorge,
you have a missing closing ")" just before </value> in <ClientProperty>.
The Recode function is defined by the OGC Symbology Encoding (SE) 1.1 specification and is not specific to app-schema. It is implemented here:
https://github.com/geotools/geotools/blob/master/modules/library/main/src/main/java/org/geotools/filter/function/RecodeFunction.java
I have tested Recode in the app-schema-tutorial configuration in sourceExpression and in ClientProperty for both codeSpace and xlink:href and it worked as expected for me in each case. Each test used a space in the key. For the xlink:href test, I changed this attribute mapping in gsml_MappedFeature.xml (mapping NAME which contains a space):
<AttributeMapping>
<targetAttribute>
gsml:specification
</targetAttribute>
<ClientProperty>
<name>xlink:href</name>
<value>Recode(NAME, 'Some mudstone', 'http://example.org/')</value>
</ClientProperty>
</AttributeMapping>
The test response for gsml:MappedFeature contains as expected:
<gsml:specification xlink:href="http://example.org/"/>
There could be something else wrong:
- What is your data source? Are your identifiers lowercase?
- Try removing line breaks from string literals.
- Do you get any error messages in your log?
Kind regards,
Ben.
On 29/12/15 01:54, Jorge Samuel Mendes de Jesus wrote:
Hi to all
I am trying to use the function Recode (also tried with Vocab and a
file) for translation of terms on app-schema mapping
In the documentation
http://docs.geoserver.org/latest/en/user/data/app-schema/cql-functions.html
we have the following example:
<OCQL>Recode(ABBREVIATION, '1GRAV', 'urn:cgi:classifier:CGI:SimpleLithology:2008:gravel',
'6ALLU', 'urn:cgi:classifier:CGI:SimpleLithology:2008:sediment')
</OCQL>
I tried to run an example but with white spaces on a <ClientProperty>,
something like this:
<ClientProperty>
<value>Recode(attribute,'Organic
Carbon','http://registry.it.csiro.au/sandbox/soil-data-ie/def/property/soOrganicCarbon’</value>
<ClientProperty>
But it doest work, I was wondering if it caused by whitespaces in
'Organic Carbon' since it is not an acronym
Thank you and happy seasons
Jorge de Jesus
Running server
OS: Linux 14.0.4
Geoserver: 2.7.4
Geotools: 13.4
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
