[Geoserver-users] Recommended method to upgrade 2.5 to 2.5.1
Hi
I just upgraded Geoserver to 2.5.1 from 2.5 using the windows installer (on a windows 2008 server installation)
It went ok and Geoserver still worked with one exception
I ended up with 2 services 2.5 and 2.5.1 with no way to easily uninstall the older service
Geoserver also seemed to be running much slower even after I turned off the old service.
Luckily I had a snapshot of the windows VM and reverted the server to before the upgrade.
I want to try again but how do I get round the double service issue ?
I’d rather not uninstall 2.5 as I’ve made a lot of config changes
Mark Ismail
Principal IT Officer
Tel: 0151 443 3021
Knowsley Council ê Westmorland Road ê Huyton ê L36 9GL
Save time – use the IT Service Desk Self Serve Application
2014-06-05 12:43 GMT+02:00 Ismail, Mark <mark.ismail@anonymised.com>:
If you save your data_directory you can upgrade without loosing any setting
you did. Just install the 2.5.1 then point it to the data_directory.
In case you don't did it, consider that you should always use a custom
folder for geoserver data_directory in a production environment.
Stefano
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
I didn’t use a custom folder – I went for default installation and setup – I will go read up on it
Mark Ismail
Tel: 0151 443 3021
From: Stefano Iacovella [mailto:stefano.iacovella@…84…]
Sent: 05 June 2014 11:49
To: Ismail, Mark
Cc: geoserver mailing list (geoserver-users@lists.sourceforge.net)
Subject: Re: [Geoserver-users] Recommended method to upgrade 2.5 to 2.5.1
2014-06-05 12:43 GMT+02:00 Ismail, Mark <mark.ismail@…6440…>:
If you save your data_directory you can upgrade without loosing any setting you did. Just install the 2.5.1 then point it to the data_directory.
In case you don’t did it, consider that you should always use a custom folder for geoserver data_directory in a production environment.
Stefano
41.95581N 12.52854E
2014-06-05 12:56 GMT+02:00 Ismail, Mark <mark.ismail@anonymised.com>:
Just restore the snapshot of your virtual machine, then copy the
data_directory contents to another folder on the file system. Then upgrade
to 2.5.1, open the web.xml file and serarch for the following code:
<context-param>
       <param-name>GEOSERVER_DATA_DIR</param-name>
       <param-value>/opt/data_dir_geoserver</param-value>
</context-param>
Uncomment it, as it is commented by default, and change the value to the
location where you saved your data_directory contents.
Stefano
41.95581N 12.52854E
I did as you suggested Stefano and I have moved my data_dir and all seemed fine until I did a wmsgetfeatureinfo
Getting an error from openlayers.js
Unhandled exception at line 450, column 350 in http://localhost:51416/Scripts/openlayers/OpenLayers.js
0x800a03ea - JavaScript runtime error: Syntax error
The error is something to do with parsing json
I will revert the server again and see if it is something to do with the 2.5.1 installation handling JSON calls differently
Mark Ismail
Tel: 0151 443 3021
Sent: 05 June 2014 12:02
To: Ismail, Mark
2014-06-05 12:56 GMT+02:00 Ismail, Mark <mark.ismail@…6440…>:
Just restore the snapshot of your virtual machine, then copy the data_directory contents to another folder on the file system. Then upgrade to 2.5.1, open the web.xml file and serarch for the following code:
GEOSERVER_DATA_DIR /opt/data_dir_geoserver
Uncomment it, as it is commented by default, and change the value to the location where you saved your data_directory contents.
Stefano
41.95581N 12.52854E
2014-06-05 14:21 GMT+02:00 Ismail, Mark <mark.ismail@anonymised.com>:
Hi Mark,
IMHO is very doubtful that the error may be related to the data_directory
location.
As first step did you checked that at startup GeoServer didn't complain
about some error in configuration?
if the startup is safe then check that the layers you use in the openLayers
web app are correctly visualized in the layers preview.
As last step I would check from firebig, or similar debugging ide, what
request proudecs the error.
Stefano
41.95581N 12.52854E
I reverted again and my json problem went away – I think I will stick with 2.5 for now
I did move my data_dir though but via environment variable as its a windows machine
Mark Ismail
Tel: 0151 443 3021
Sent: 05 June 2014 13:28
To: ‘Stefano Iacovella’
Mark Ismail
Tel: 0151 443 3021
To: Ismail, Mark
Stefano
41.95581N 12.52854E
This e-mail and any attachments are confidential. It may contain privileged information and is intended for the named recipient(s) only. It must not be distributed without consent. If you are not one of the intended recipients, please notify the sender immediately and do not disclose, distribute, or retain this email or any part of it and do not take any action based on it.
Unless expressly stated, opinions in this email are those of the individual sender, and not of Knowsley MBC. Legally binding obligations can only be created for, or be entered into on behalf of, Knowsley MBC by duly authorised officers or representatives.
Knowsley MBC excludes any liability whatsoever for any offence caused, any direct or consequential loss arising from the use, or reliance on, this e-mail or its contents. We believe but do not warrant that this e-mail and any attachments are virus free. You must therefore take full responsibility for virus checking and no responsibility is accepted for loss or damage arising from viruses or changes made to this message after it was sent. Knowsley MBC reserves the right to monitor and/or record all e-mail communications through its network in accordance with relevant legislation.
