[Geoserver-users] reconfiguring gewebcache for gda94
Dear GeoServers,
I am seeing some very odd behaviour when trying to use a previously working (but older) geowebcache.xml file in geoserver 2.0.2.
I have created a custom gridset to use EPSG:4283 (using a short gridset name of GDA94) in geowebcache.xml.
<?xml version="1.0" encoding="utf-8"?>
<gwcConfiguration xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xsi:noNamespaceSchemaLocation=“http://geowebcache.org/schema/1.2.0/geowebcache.xsd
xmlns=“http://geowebcache.org/schema/1.2.0”>
1.2.0
120
GDA94
4283
137.8125000-29.5751949
154.2041016-10.3271480
true
10
111226.31
512
512
topp:telascience
GDA94
0
9
http://localhost:8080/geoserver/wms
topp:telascience
topp:100ktopo
GDA94
0
9
topp:100ktopo
tiger:common_estate_label
GDA94
0
9
tiger:common_estate
GDA94
0
9
tiger:common_estate
tiger:common_town
GDA94
0
9
tiger:common_town
This worked fine before upgrading to the current geoserver 2.0.2, except now I see the following in the GWC demo page –
topp:100ktopo
Seed this layer
EPSG:4283_topp:100kt… OpenLayers: [png, gif, png8, jpeg]
EPSG:4326 OpenLayers: [png, gif, png8, jpeg] KML: [png, gif, png8, jpeg, kml]
GDA94 OpenLayers: [png, gif, png8, jpeg]
EPSG:900913 OpenLayers: [png, gif, png8, jpeg]
Why has the EPSG:4283_topp:100kt… suddenly appeared when it is isn’t even listed in geowebcache.xml ?
I am also now seeing an error appearing in the geoserver.log file that the tilesize (512x512) does not match (256x256) ?
If I change the tilesize of course all the old tiles are now invalid and will need to be reseeded or generated on the fly.
Does anyone in Aus have a more local example of geowebcache.xml for GDA94 and do I need to be more specific about other parameters now in the config file ?
Many thanks,
Shaun
Think B4U Print
1 ream of paper = 6% of a tree and 5.4kg CO2 in the atmosphere
3 sheets of A4 paper = 1 litre of water
I think you forgot to tell us what the odd behaviour was?
I also note, from testing, that the geowebcache configuration shipped with geoserver 2.0.2 was not quite working; Arne applied some patches in order to get me a demo machine to test against.
Jody
On 22/08/2010, at 3:41 PM, Kolomeitz Shaun wrote:
Dear GeoServers,
1.2.0
120
GDA94
4283
true
10
111226.31
512
512
topp:telascience
GDA94
0
9
topp:telascience
topp:100ktopo
GDA94
0
9
topp:100ktopo
GDA94
0
9
tiger:common_estate
GDA94
0
9
tiger:common_estate
tiger:common_town
GDA94
0
9
tiger:common_town
topp:100ktopo
Seed this layer
Many thanks,
Shaun
Think B4U Print
This SF.net email is sponsored by
Make an app they can’t live without
Enter the BlackBerry Developer Challenge
http://p.sf.net/sfu/RIM-dev2dev _______________________________________________
Geoserver-users mailing list
Jody,
Is it possible to get the patch (Arne ?), or am I better off trying to use geowebcache as a separate WAR ?
Sorry, the odd behaviour is that
  1. Geoserver is creating Directories in the disk cache called EPSG_4283_topp_100ktopo_01, 02 etc despite a custom Grid being defined “GDA94”
  2. Requests that used to work fine are now not working and return errors on the tilesize
  3. The GDA94 cache is used when I zoom down a few levels, and then suddenly geoserver creates directories called EPSG_4283_topp_100ktopo_04 and generates tiles in those. What the ???
I’d like to have a working disk cache again, but more importantly I’d like to be able to understand how the heck it is meant to be setup, because fairly obviously I am missing something with the custom grid. I’d like to remove the default 4326 and 900913 as we never use them.
I’ve been looking for a well explained working example as the docs really don’t cut it for me.
Shaun
From: Jody Garnett [mailto:jody.garnett@anonymised.com]
Sent: Sunday, 22 August 2010 8:55 PM
To: Kolomeitz Shaun
Subject: Re: [Geoserver-users] reconfiguring gewebcache for gda94
Jody
Dear GeoServers,
1.2.0
120
GDA94
4283
true
10
111226.31
512
512
topp:telascience
GDA94
0
9
topp:telascience
topp:100ktopo
GDA94
0
9
topp:100ktopo
GDA94
0
9
tiger:common_estate
GDA94
0
9
tiger:common_estate
tiger:common_town
GDA94
0
9
tiger:common_town
topp:100ktopo
Seed this layer
Many thanks,
Shaun
Think B4U Print
The bug reports are here:
- http://jira.codehaus.org/browse/UDIG-1705
- http://jira.codehaus.org/browse/GEOS-4076
The working server is:
- http://demo.opengeo.org/geoserver/gwc/service/wms?request=getcapabilities&tiled=true
Jody
On Mon, Aug 23, 2010 at 7:49 AM, Kolomeitz Shaun
<shaun.kolomeitz@anonymised.com> wrote:
Jody,
1) Geoserver is creating Directories in the disk cache called
“GDA94”
2) Requests that used to work fine are now not working and return
3) The GDA94 cache is used when I zoom down a few levels, and then
Shaun
To: Kolomeitz Shaun
Jody
Dear GeoServers,
<gwcConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
xsi:noNamespaceSchemaLocation="http://geowebcache.org/schema/1.2.0/geowebcache.xsd&quot;
xmlns="http://geowebcache.org/schema/1.2.0&quot;&gt;
<version>1.2.0</version>
<backendTimeout>120</backendTimeout>
<gridSets>
<gridSet>
<name>GDA94</name>
<srs><number>4283</number></srs>
<extent><coords>
&lt;double&gt;137\.8125000&lt;/double&gt;&lt;double&gt;\-29\.5751949&lt;/double&gt;
&lt;double&gt;154\.2041016&lt;/double&gt;&lt;double&gt;\-10\.3271480&lt;/double&gt;
</coords></extent>
<alignTopLeft>true</alignTopLeft>
<levels>10</levels>
<metersPerUnit>111226.31</metersPerUnit>
<tileHeight>512</tileHeight>
<tileWidth>512</tileWidth>
</gridSet>
</gridSets>
<layers>
<wmsLayer><name>topp:telascience</name>
<gridSubsets><gridSubset><gridSetName>GDA94</gridSetName>
&lt;zoomStart&gt;0&lt;/zoomStart&gt;
&lt;zoomStop&gt;9&lt;/zoomStop&gt;
</gridSubset></gridSubsets>
<wmsUrl><string>http://localhost:8080/geoserver/wms&lt;/string&gt;&lt;/wmsUrl&gt;
<wmsLayers>topp:telascience</wmsLayers>
</wmsLayer>
<wmsLayer><name>topp:100ktopo</name>
<wmsLayers>topp:100ktopo</wmsLayers>
</wmsLayer>
<wmsLayer><name>tiger:common_estate_label</name>
<wmsLayers>tiger:common_estate_label</wmsLayers>
</wmsLayer>
<wmsLayer><name>tiger:common_estate</name>
</gridSubset>
</gridSubsets>
<wmsLayers>tiger:common_estate</wmsLayers>
</wmsLayer>
<wmsLayer><name>tiger:common_town</name>
<gridSubsets><gridSubset> <gridSetName>GDA94</gridSetName>
</gridSubset>
</gridSubsets>
<wmsLayers>tiger:common_town</wmsLayers>
</wmsLayer>
</layers>
</gwcConfiguration>
topp:100ktopo
Seed this layer
EPSG:4283_topp:100kt... OpenLayers: [png, gif, png8, jpeg]
png8, jpeg, kml]
file ?
Many thanks,
Shaun
Think B4U Print
Make an app they can't live without
Best Open Source Mac Front-Ends 2024
  Jody: You are discussing this as if this is related to uDig / WMS-C getcapabilities, but I don't see Shaun going anywhere near that?
The embedded version of GWC tries to configure itself automatically based on the GeoServer catalog. My guess is that this is the layers you are seeing, and that your configuration file is not being picked up for some other reason. Check the logs right after startup, there should be an error message or something there.
I'm on vacation and a prepaid 3G account this week, I can have a closer look next week when I catch up on emails.
-Arne
Jody
Jody,
“GDA94”
Shaun
To: Kolomeitz Shaun
Jody
Dear GeoServers,
<gridSets>
  <gridSet>
   <name>GDA94</name>
   <extent><coords>
     <double>137.8125000</double><double>-29.5751949</double>
     <double>154.2041016</double><double>-10.3271480</double>
    </coords></extent>
   <levels>10</levels>
  </gridSet>
</gridSets>
<layers>
     <zoomStart>0</zoomStart>
     <zoomStop>9</zoomStop>
</wmsLayer>
</wmsLayer>
</wmsLayer>
    </gridSubset>
   </gridSubsets>
</wmsLayer>
    </gridSubset>
   </gridSubsets>
</wmsLayer>
</layers>
</gwcConfiguration>
topp:100ktopo
Seed this layer
png8, jpeg, kml]
file ?
Many thanks,
Shaun
Think B4U Print
  Hi Shaun,
finally had a chance to look through it and try it. I don't really see a problem, but you probably have an (occasional) collision between what is configured automatically and what is configured from the XML file.
Change
to something else (tiger:common_town_cached), it'll probably make the problem disappear for good, and it'll be much easier to debug.
This is true in general, don't use the the same value in <name> as in <wmsLayers> unless you really know what you are doing.
-Arne
-Arne
Jody
Jody,
“GDA94”
Shaun
To: Kolomeitz Shaun
Jody
Dear GeoServers,
<gridSets>
   <gridSet>
    <name>GDA94</name>
    <extent><coords>
     </coords></extent>
    <levels>10</levels>
   </gridSet>
</gridSets>
<layers>
</wmsLayer>
</wmsLayer>
</wmsLayer>
     </gridSubset>
    </gridSubsets>
</wmsLayer>
     </gridSubset>
    </gridSubsets>
</wmsLayer>
</layers>
</gwcConfiguration>
