[Geoserver-users] reduce clipped labels at the edge of tiles
Hello,
I would like to reduce or hopefully eliminate the number of clipped labels on a tiled parcel map. Having a larger metatile helps, but does not eliminate the clipped parcels. I have also been trying to figure out what the best gutter settings are. Anyways, is there a way to eliminate clipped labels? If so, what are the recommended settings?
Thanks
Mark Volz
On Wed, Mar 13, 2013 at 2:05 PM, Mark Volz <MarkVolz@anonymised.com> wrote:
Hello,
GeoServer should never paint a label that is not fully contained in the requested area… so if you don’t specify gutters, you should
not get any clipped label.
Can you elaborate a bit about what you’re doing?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea,
In addition to removing the gutter, I found I needed to adjust “polygonAlign” from ortho to manual. Now the labels look great on tiled layers.
Thank You for your help.
Mark Volz
GIS Specialist
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: Wednesday, March 13, 2013 8:31 AM
To: Mark Volz
Subject: Re: [Geoserver-users] reduce clipped labels at the edge of tiles
Hello,
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Mar 14, 2013 at 4:35 PM, Mark Volz <MarkVolz@anonymised.com> wrote:
Andrea,
Ah, the adjustment on “ortho” is unexpected. Can you open a bug report on jira.codehaus.org and maybe attach style and screenshots?
Ing. Andrea Aime
@geowolf
Technical Lead
