[Geoserver-users] Reg Map not printed in mapfish print when WMS layer is Secured
In GeoEXT print ,map is not printed When WMS layer is secured and getting java.io.IOException: The byte array is not a recognized imageformat. But the same print is working fine when layer is public and also how to change output filename dymanically form javascript.Please guide wt i have to do…Give some suggestions.
Herewith i have enclosed sample YAML file for reference…
config.yaml (3.63 KB)
we are currently facing the same problem and we made a patch for MapFish 2.0 to allow forwarding of basic authentication from mapfish-print to Geoserver when printing.
What kind of authentication are you using to access your secured layers? Basic or something more complex?
To set the output file name you can use the “outputFilename” property in your json spec, for example:
layout: ‘A4 portrait’,
…CUSTOM_PARAMS…
srs: ‘EPSG:4326’,
units: ‘degrees’,
geodetic: false,
outputFilename: ‘custom-file-name’,
Mauro
2014-02-28 13:37 GMT+01:00 geo gis <gisgeoserver@anonymised.com>:
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
