Hi
I got around the printing authenticated layers issue by creating a user
in Geoserver called printer with access to all layers.
You can then add this security block in your config.yaml to send all
print requests as a specified user:
Security:
- !basicAuth
Matcher: !dnsMatch
host: geoserver
port: 8080
username: printer
password: password
preemptive: true
As for the filename there’s an outputFilename: parameter you can put in
the config.yaml, I’m guessing you can substitute any variable that
you’re sending to mapfish in there as you do elsewhere:
outputFilename: ‘${customfilename}’
Hope this helps
Tom
Date: Fri, 28 Feb 2014 18:07:38 +0530
Subject: [Geoserver-users] Fwd: Reg Map not printed in mapfish print
when WMS layer is Secured
Message-ID:
<CAG2EM7kN-Aiv4-rBunnj0CR1zcpf5MnZRxuBg=di9GApam9VWw@anonymised.com>
Content-Type: text/plain; charset=“iso-8859-1”
In GeoEXT print ,map is not printed When WMS layer is secured and
getting java.io.IOException:
The byte array is not a recognized imageformat. But the same print is
working fine when layer is public and also how to change output filename
dymanically form javascript.Please guide wt i have to do…Give some
suggestions.
Herewith i have enclosed sample YAML file for reference…
An HTML attachment was scrubbed…
A non-text attachment was scrubbed…
Type: application/octet-stream
Desc: not available
