Can anyone give me suggestion for splitting polygon in Openlayers is possible,If possible means give me the url…I tried out the Split feature example by using this url
http://openlayers.org/dev/examples/split-feature.html
But it is working for line only…I need Polygon Split example in Openlayers
I guess the OpenLayers mailing list would be more appropriate for this question.
However, I recently came across this small application for drawing on a map in OpenLayers 2, it has a function for splitting polygons, you could look into the code?
http://ole.geops.de/
Aleksander
geo gis <gisgeoserver@anonymised.com> , 3/3/2014 1:23 PM:
Subversion Kills Productivity. Get off Subversion & Make the Move to Perforce.
With Perforce, you get hassle-free workflows. Merge that actually works.
Faster operations. Version large binaries. Built-in WAN optimization and the
freedom to use Git, Perforce or both. Make the move to Perforce.
http://pubads.g.doubleclick.net/gampad/clk?id=122218951&iu=/4140/ostg.clktrk
Geoserver-users mailing list
