Hi Piotr,
I don’t think you can use regexes with those two, but you can use strMatches, see here the reference:
http://docs.geoserver.org/latest/en/user/filter/function_reference.html
Mind one thing, these filter functions are not sent down to the database, they will be evaluated as the data is streamed up in memory (just so you know, in case you expected otherwise).
On Fri, Jun 17, 2016 at 11:54 AM, Piotr Kosz <piotr.kosz.91@anonymised.com> wrote:
I wonder whether Geoserver support regular expressions in “strSubstring” and “strSubstringStart” filter functions. I would like to label my layers with attribute-filtering SLD, and in Geoserver User Manual I have found these 2 functions, which I believe are suitable. But I am not sure if regular expressions work with this two aforementioned, and how to put my regex into SLD properly (I mean which markups should be used).
Thanks in advance for your answer,
Peter
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity planning
reports. http://sdm.link/zohomanageengine
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
