[Geoserver-users] Reload config via Wicket UI (2.0 beta)?
In GeoServer 1.7 it was possible to reload (Load/Apply) the configuration via the web user interface. Is this possible in the new Wicket UI in GeoServer trunk / 2.0 beta?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
This may get retracted when the other side of the globe wakes up:
I believe that disappeared when Submit + Apply + Save was merged into "Ok". Mangling the UI configuration files outside the UI has never been supported, so I'm not sure it was brought up when we discussed this on the dev list* about a year ago.
Can always reload the servlet, it has much of the same effect anyway.
-Arne
*: " New UI: The Persistence of Save (or The Saving of Persist)" , "Temp vs persistent"
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
If you want a full reload, as long as you're running in development
mode the "developer toolbar" shows up and has a button that does
that.
If you're running in deployment mode nope, no chance, thought I
believe we want one (think people fiddling manually with the
config files for... oh yeah, setting up app schema configurations
for example :wink: )
Andrea Aime
OK. I'll need to enable and configure the manager servlet, though.
that.
I would not be against a "reload" feature, but I can see it quickly turning into a crutch. I foresee it not acting exactly like the old one with not everything actually getting reloaded. I fear us having to spend time reimplementing the the load/save functionality we have been working so hard to kill :slight_smile:
Justin Deoliveira
that.
Hmmm... I put it back in the dev toolbar because
restarting geoserver to get the same behaviour was too slow.
It helped in a number of occasion, particularly when debugging
geoserver or when dealing with the geoserver caps link being missing
upon data directory conversion.
I'd say to put it in some secondary page for users, like the status one.
Andrea Aime
