On Tue, Nov 24, 2015 at 7:49 PM, Martin Davis <mtnclimb@anonymised.com> wrote:
Ok, so was referring to custom code solution.
Not really, the one I've outlined could well get into core (if other core
devs agree)
Not an option for us now, so will have to look at a client-side solution,
unless there's another server-side option.
Perhaps this could be an future enhancement to Coverage Views (if that's
the right place for it).
Hum... not really, coverage views only build rasters, which are made of
numbers, and to do what you
want to do, we'd need one made of strings instead
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
