Dear GeoServants,
While I can access our GeoServer without specifying any port number in the URL, the server is still reporting itself with a “:80” tacked on the end. Do any of you know how to configure things to leave that off? We are running GeoServer through Tomcat on Ubuntu Linux. To give you an example of where I am seeing this, here is an example of one of our virtual Web Map Service (WMS) GetCapabilities:
http://geo.pacioos.hawaii.edu/geoserver/PACIOOS/as_pibhmc_swa_bathy40m_hillshade/ows?service=WMS&version=1.3.0&request=GetCapabilities
When you look at any of the http://geo.pacioos.hawaii.edu URLs listed inside of the above XML document, they always get listed as http://geo.pacioos.hawaii.edu:80 (i.e. with “:80”). Here is a quick example from the top line, but “:80” also appears for all end points throughout the GetCap document:
<WMS_Capabilities version=“1.3.0” updateSequence=“17202” xsi:schemaLocation=“http://www.opengis.net/wms http://geo.pacioos.hawaii.edu:80/geoserver/schemas/wms/1.3.0/capabilities_1_3_0.xsd”>
Is there a way to hide the “:80” part of these URLs through some Apache or Tomcat or GeoServer or other configuration? Not a big deal, but would be nice to squash this cosmetic smudge.
Aloha,
John Maurer
Pacific Islands Ocean Observing System (PacIOOS)
University of Hawaii at Manoa
John,
if you set Proxy Base URL in your GeoServer / Settings / Global to:
then your schema and capabilities URLs will be encoded without the :80.
Kind regards,
Ben.
On 21/01/16 08:25, John Maurer wrote:
Dear GeoServants,
URL, the server is still reporting itself with a ":80" tacked on the end.
http://geo.pacioos.hawaii.edu:80 (i.e. with ":80"). Here is a quick example
from the top line, but ":80" also appears for all end points throughout the
GetCap document:
<WMS_Capabilities version="1.3.0" updateSequence="17202"
xsi:schemaLocation="http://www.opengis.net/wms
Is there a way to hide the ":80" part of these URLs through some Apache or
Aloha,
John Maurer
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
