Hi list,
Is there a way to easily remove specific layers from being available via WFS? I want to keep a WFS service running but there are about 10 layers I don’t want to be accessible via it. I can stop them from being advertised (on all services), but strictly speaking they’ll still be available via WFS.
Suggestions?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Tue, Oct 29, 2013 at 3:28 PM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi list,
don't want to be accessible via it. I can stop them from being advertised
(on all services), but strictly speaking they'll still be available via WFS.
As far as I know, it can be done with a security system such as GeoFence
(the built-in one is not complete enough)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hmmmm, ok. I guess that I could alternately create a new workspace and stick them all in there; but that’s a big hastle at this point (the layers are already very embedded).
Jonathan
On 29 October 2013 14:38, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Tue, Oct 29, 2013 at 3:28 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi list,
As far as I know, it can be done with a security system such as GeoFence (the built-in one is not complete enough)
Ing. Andrea Aime
@geowolf
Technical Lead
