On Wed, May 18, 2016 at 11:38 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Federico,
trying to remove twice seems like a bug, do you have the stack traces of the
two invocations, or a description of where they are coming from?
On Wed, May 18, 2016 at 10:20 AM, Federico C.Guizzardi <cippinofg@anonymised.com> wrote:
Hi All,
I’m recently testing jdbcconfig (on geoserver 2.10, 2.9, 2,8), and I discover
an interesting thing related workspaces remove function: it is called twice!
At beginning, I thought it was a bug of jdbcconfig, but today I got a confirm
that two calls are in geoserver code.
To verify that, is enough to add a
System.out.println(“Removing Workspace”);
in CatalogImpl.java (package org.geoserver.catalog.impl) at line 1212, compile
and deploy.
After that, run application server (tomcat 8 for me), create a workspace and
remove that. On catalina.out, you should see the message twice.
Using geoserver, this is not a bug, but in jdbcconfig there is
findObjectId(…)
at line 592 of ConfigDatabase.java, that fails on the second call, because
there isn’t the workspace.
Before proposing a patch, I’d like to understand why there are two calls to
remove method (may be there’s a good reason, but actually I can’t see it).
Depending on it, which idea is better: remove duplicated call or allow
removing not existing workspaces without generating an exception.
Cheers.
.Federico C Guizzardi
_
abstract.it
Registro Imprese di Napoli 788429 / Cap. Soc. 10.000 Euro I.V. Avvertenze
Legali - D. Lgs. 196/03 Tutela dei dati personali. Le informazioni contenute
in questo messaggio e in ogni eventuale allegato sono riservate e ne è vietata
ogni forma di diffusione. Se avete ricevuto questa comunicazione per errore,
Vi preghiamo di informare immediatamente il mittente del messaggio e di
eliminare l’e-mail.
Mobile security can be enabling, not merely restricting. Employees who
bring their own devices (BYOD) to work are irked by the imposition of MDM
restrictions. Mobile Device Manager Plus allows you to control only the
apps on BYO-devices by containerizing them, leaving personal data untouched!
https://ad.doubleclick.net/ddm/clk/304595813;131938128;j
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
dott. Federico Guizzardi
Abstract s.r.l.
