[Geoserver-users] Rendering transformation error
Hey,
I'm getting an error when I try to apply a rendering transformation (ex.
contours from a dem):
org.geoserver.platform.ServiceException: Rendering process failed
Failed to evaluate the process function, error is:
java.lang.IllegalArgumentException: The input argument(s) may not be null.
This started to happen when I upgraded from version 2.2.x to 2.3.x and then
2.4RC. Therefore I guess raster and style should be fine. Am I missing
something in the upgrades?
Thanks for your help!
Paolo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-transformation-error-tp5073874.html
On Thu, Aug 22, 2013 at 7:45 PM, Paolo Pasquali <paolo.pasquali@anonymised.com>wrote:
Hey,
The error above is not of much help alone. Do you have the style in
question?
And eventually as sample of the data to reproduce the issue (if would
be great if it could be reproducable against the sample sfdem layer)
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the quick reply, Andrea.
The error occurs also against the sfdem layer and with the GeoServer sample sld you can find at http://docs.geoserver.org/stable/en/user/styling/sld-extensions/rendering-transform.html
Please note that I get the error with every layer and style that worked in previous versions.
Thanks again.
Ciao
Paolo
On Thu, Aug 22, 2013 at 8:14 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Aug 22, 2013 at 7:45 PM, Paolo Pasquali <paolo.pasquali@anonymised.com> wrote:
Hey,
I’m getting an error when I try to apply a rendering transformation (ex.
The error above is not of much help alone. Do you have the style in question?
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Aug 22, 2013 at 8:57 PM, Paolo Pasquali <paolo.pasquali@anonymised.com>wrote:
previous versions.
Sorry for the silly question but I have to ask: do you have the WPS
extension installed, and the one that comes with the
specific version of GeoServer you are using? Extensions are version
specific, you cannot install the wps for
geoserver 2.1 in v 2.3
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Yep, the wps capabilities responds.
http://playground.ithacaweb.org/geoserver/ows?service=wps&version=1.0.0&request=GetCapabilities
I'm currently running GeoServer 2.3.5 and the wps jar is marked 2.3.5
Ciao
Paolo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-transformation-error-tp5073874p5073938.html
I tried the gs:Heatmap transformation and works fine. So it seems it is
gs:Contour specific. Is there any further test I can try?
Thanks
Bye
Paolo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Rendering-transformation-error-tp5073874p5075944.html
