If that’s the case, raising its Priority would solve that problem, just set a value
higher than 1000 (that being the default, yes, I know, it’s a weird default value).
Of course you’d lose other labels.
Another option would be to give it a large maxDisplacement value to help it
locate a free spot that’s not in the center.
On Wed, May 10, 2017 at 9:19 AM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
Do I undestand right that the desire is not necessarily to get multiple labels but one label at any scale, at any region of interest?
Polygons labels are placed dynamically so with basic WMS it should not be possible to zoom past the label. The label is set to partial polygons if there are place for them. You can test with demo layer “states” with QGIS or OpenJUMP and you should experience that you can’t zoom past labels. Quick test with browser:
http://localhost:8080/geoserver/wms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1601&HEIGHT=839&LAYERS=topp%3Astates&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=-115.408,34.685,-113.877,35.487&SRS=EPSG:4326&STYLES=
-Jukka Rahkonen-
Andrea Aime wrote:
Re: [Geoserver-users] Repeat Labels Inside of Polygons
there is indeed no vendor option to get the behavior your want, normally
people complain about it and ask about getting rid of it, so no support
was developed to get it in untiled mode.
Anyways, patches welcomed, if you are interested I can point you at where
the action is (roughly, gt-render module down in Geotools)
On Wed, May 10, 2017 at 12:36 AM, FunkMonkey33 <aedwards@anonymised.com17…com> wrote:
When you zoom into a large polygon, let’s say a County, you often zoom past
the label, and then you don’t know what county you’re in.
LineSymbolizer allows you to repeat labels, but I haven’t found any way to
repeat them in a polygon. No combination of maxDisplacement or repeat in
the SLD is having the desired effect.
Extensive googling only came up with posts about labels repeating due to
being served as tiles, which is not the behavior I’m going for.
Thanks!
Aaron
View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeat-Labels-Inside-of-Polygons-tp5319970.html
Geoserver-users mailing list
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
