[Geoserver-users] Repeated labels for PolygonSymbolizer
     Below is the FeatureTypeStyle that draws polygon with labels. As you
can see from the attached image, the labels are repeated many times over the
polygon. Is there a <VendorOption> that I can use to suppress the behavior?
<sld:FeatureTypeStyle>
        <sld:Rule>
          <Name>Landing area</Name>
          <Title></Title>
          <ogc:Filter>
            <ogc:Or>
              <ogc:And>
<ogc:PropertyIsEqualTo><ogc:PropertyName>f_code</ogc:PropertyName><ogc:Literal>BD000</ogc:Literal></ogc:PropertyIsEqualTo>
<ogc:PropertyIsGreaterThan><ogc:PropertyName>hdp</ogc:PropertyName><ogc:Literal>20</ogc:Literal></ogc:PropertyIsGreaterThan>
              </ogc:And>
               <ogc:And>
<ogc:PropertyIsEqualTo><ogc:PropertyName>f_code</ogc:PropertyName><ogc:Literal>BD200</ogc:Literal></ogc:PropertyIsEqualTo>
<ogc:PropertyIsEqualTo><ogc:PropertyName>vrr</ogc:PropertyName><ogc:Literal>4</ogc:Literal></ogc:PropertyIsEqualTo>
              </ogc:And>
            </ogc:Or>
          </ogc:Filter>
          <PolygonSymbolizer>
            <Stroke>
              <sld:CssParameter name="stroke">#92A4A6</sld:CssParameter>
              <sld:CssParameter name="stroke-width">2</sld:CssParameter>
              <sld:CssParameter name="stroke-dasharray">12
            </Stroke>
          </PolygonSymbolizer>
         <sld:TextSymbolizer>
            <sld:Label>
              <ogc:PropertyName>txt</ogc:PropertyName>
            </sld:Label>
            <sld:Font>
              <sld:CssParameter name="font-family">Arial</sld:CssParameter>
              <sld:CssParameter name="font-size">8</sld:CssParameter>
              <sld:CssParameter name="font-style">normal</sld:CssParameter>
              <sld:CssParameter name="font-weight">bold</sld:CssParameter>
            </sld:Font>
            <sld:LabelPlacement>
              <sld:PointPlacement>
                <sld:AnchorPoint>
                  <sld:AnchorPointX>0.5</sld:AnchorPointX>
                  <sld:AnchorPointY>0.5</sld:AnchorPointY>
                </sld:AnchorPoint>
              </sld:PointPlacement>
            </sld:LabelPlacement>
            <sld:Halo>
              <sld:Radius>3</sld:Radius>
              <sld:Fill>
                <sld:CssParameter name="fill">#FFFFFF</sld:CssParameter>
              </sld:Fill>
            </sld:Halo>
          </sld:TextSymbolizer>
        </sld:Rule>
      </sld:FeatureTypeStyle>
<http://osgeo-org.1560.x6.nabble.com/file/n5146148/repeated-label.jpg&gt;
I greatly appreciate any comments on this issues.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/Repeated-labels-for-PolygonSymbolizer-tp5146148.html
Hi Tam,
Grouping should do what you want - http://docs.geoserver.org/stable/en/user/styling/sld-reference/labeling.html#grouping-features-group
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Jonathan
polygon. Is there a that I can use to suppress the behavior?
sld:Rule
Landing area
ogc:PropertyIsEqualToogc:PropertyNamef_code</ogc:PropertyName>ogc:LiteralBD000</ogc:Literal></ogc:PropertyIsEqualTo>
ogc:PropertyIsGreaterThanogc:PropertyNamehdp</ogc:PropertyName>ogc:Literal20</ogc:Literal></ogc:PropertyIsGreaterThan>
</ogc:And>
ogc:And
ogc:PropertyIsEqualToogc:PropertyNamef_code</ogc:PropertyName>ogc:LiteralBD200</ogc:Literal></ogc:PropertyIsEqualTo>
ogc:PropertyIsEqualToogc:PropertyNamevrr</ogc:PropertyName>ogc:Literal4</ogc:Literal></ogc:PropertyIsEqualTo>
</ogc:And>
</ogc:Or>
</ogc:Filter>
#92A4A6 2 12 6 txt Arial 8 normal bold 0.5 0.5 3 #FFFFFF
</sld:Rule>
<http://osgeo-org.1560.x6.nabble.com/file/n5146148/repeated-label.jpg>
Tam
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
Geoserver-users mailing list
Keep in mind that if you call the WMS layer for tiles, you will probably get repeated labels as well since each individual tile is requested independently of the other tiles.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@anonymised.com
Hi Tam,
Jonathan
sld:Rule
Landing area
</ogc:And>
ogc:And
</ogc:And>
</ogc:Or>
</ogc:Filter>
</sld:Rule>
Tam
