[Geoserver-users] Reprojected point disappears past -67 south [Sec=Unclassified]
Soo... I've found quite a few issues, and I think I fixed them all,
but only on trunk, on 1.5.x I could to make 3031 work (if you have
any magic recipe of your own, please share, it's probably just an
issue of setting up the proper wkt definition :)).
I used the WKT as defined by SCAR at
http://www.antsdi.scar.org/standardsspecifications/refsystemandprojectio
ns/projections/antarctic_wkt.txt/view (my epsg.properties is attached).
One thing, the srsName you provided in the SLD is invalid, the correct
form is
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326"
Thanks for pointing that out :slight_smile:
If you try out tomorrow's trunk nightly build you should get the
same image as the one attached with the following request
I will certainly give that a go. Thanks Andrea, I appreciate your
persistence.
Miles
___________________________________________________________________________
    Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
        Visit our web site at http://www.antarctica.gov.au/
epsg.properties (630 Bytes)
