If you try out tomorrow's trunk nightly build you should get the same
as the one attached with the following request (fix the sld url to
point to
your own):
http://localhost:8080/geoserver/wms?bgcolor=0xf2AAAFF&bbox=-2761827.8078
423
585,-2589793.885787334,2850918.460493497,2421607.9999959785&SLD=http://l
oca
lhost:8080/geoserver/www/test.sld&Format=image/png&request=GetMap&width=
600
&height=600&SRS=EPSG:3031
Hi Andrea,
That's working perfectly for me now using the nightly build.
Miles
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
