150 meters is an entity compatible with the datum shift error.
You can try to override the EPSG:3004 SRS with the following values:
3004=PROJCS[“Monte Mario / Italy zone 2”,GEOGCS[“Monte Mario”,DATUM[“Monte_Mario”,SPHEROID[“International 1924”,6378388,297,AUTHORITY[“EPSG”,“7022”]],TOWGS84[-168.6, -34, -38.6, -0.374, -0.679, -1.379, -
9.48],AUTHORITY[“EPSG”,“6265”]],PRIMEM[“Greenwich”,0,AUTHORITY[“EPSG”,“8901”]],UNIT[“degree”,0.01745329251994328,AUTHORITY[“EPSG”,“9122”]],AUTHORITY[“EPSG”,“4265”]],UNIT[“metre”,1,AUTHORITY[“EPSG”,“9001”]],PROJECTION[“Transverse_Mercator”],PARAMETER[“latitude_of_origin”,0],PARAMETER[“central_meridian”,15],PARAMETER[“scale_factor”,0.9996],PARAMETER[“false_easting”,2520000],PARAMETER[“false_northing”,0],AUTHORITY[“EPSG”,“3004”],AXIS[“X”,EAST],AXIS[“Y”,NORTH]]
You need to had the previous string in the user_projections/epsg_overrides.properties file inside the GeoServer data dir
Stefano
2015-01-26 10:44 GMT+01:00 Giuseppe Falcone <falcone.giuseppe@anonymised.com>:
Thanks for the quick response.
The behaviour is the same.
The geoserver version is 2.6.1
I see these metadata of a single tile with an other software:
FILENAME=404060e.ecw
DESCRIPTION=404060e.ecw
UPPER LEFT X=2443320.000
UPPER LEFT Y=4600240.000
LOWER RIGHT X=2450540.000
LOWER RIGHT Y=4594410.000
WEST LONGITUDE=14° 04’ 50.2118" E
NORTH LATITUDE=41° 33’ 00.2937" N
EAST LONGITUDE=14° 10’ 04.2429" E
SOUTH LATITUDE=41° 29’ 48.9016" N
UL CORNER LONGITUDE=14° 04’ 50.2118" E
UL CORNER LATITUDE=41° 32’ 57.9194" N
UR CORNER LONGITUDE=14° 10’ 01.8200" E
UR CORNER LATITUDE=41° 33’ 00.2937" N
LR CORNER LONGITUDE=14° 10’ 04.2429" E
LR CORNER LATITUDE=41° 29’ 51.2716" N
LL CORNER LONGITUDE=14° 04’ 52.8864" E
LL CORNER LATITUDE=41° 29’ 48.9016" N
PROJ_DESC=Transverse Mercator / ROME / meters
PROJ_DATUM=ROME 1940 [MONTE MARIO] (GREENWICH)
PROJ_UNITS=meters
COVERED AREA=42.093 sq km
NUM COLUMNS=14440
NUM ROWS=11660
NUM BANDS=3
COLOR BANDS=0,1,2
PIXEL WIDTH=0.5 meters
PIXEL HEIGHT=0.5 meters
BIT DEPTH=24
PROJ_NAME=TMBOAGA2
DATUM_NAME=MONTEMAR
TARGET_COMPRESSION=1:4
Giuseppe
41.95581N 12.52854E
http://www.linkedin.com/in/stefanoiacovella
http://twitter.com/#!/Iacovellas
2015-01-26 10:24 GMT+01:00 Stefano Iacovella <stefano.iacovella@anonymised.com>:
2015-01-26 10:12 GMT+01:00 Giuseppe Falcone <falcone.giuseppe@anonymised.com>:
Any reference system I set as declared srs (EPSG:32633, EPSG:26592), and any selection I set in srs handling field, the layer is drawn with a vertical displacement of about 150 meters down.
Any idea about this?
Thanks a lot.
Ciao Giuseppe,
Did you try with EPSG:3004 as declared SRS?
Stefano
41.95581N 12.52854E
