I have entities in a Postgis Datastore using EPSG:4326 and I try to reproject them with :
http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&srs=EPSG:27572
but I get an error :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
java.lang.RuntimeException: Cannot force SRS EPSG:27572 when native is EPSG:4326, try not specifying the SRS.
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
Hi Laurent,
I am not sure but it seems that you are trying to force the underlying
native type to be a different srs than the driver thinks is the native
one. Did you specify 27572 on the feature editor page when you added the
feature type?
-Justin
laurent pierre wrote:
<http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&srs=EPSG:27572>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
</ServiceException></ServiceExceptionReport>
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
!DSPAM:4007,475fbf6a306211336712104!
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
laurent pierre ha scritto:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd"> <ServiceExceptionReport version="1.1.1" > <ServiceException>
Hmm... that looks more like a limitation of the wms reflector being
unable to handle map reprojection.
That error comes out of DefaultWebMapService.autoSetBoundsAndSize()
which is used by the reflector to guess map bounds and size...
Arne, afaik you were the last one to work on this. Any comment?
Yes, I made a mistake. I should had written crs instead of srs to choose another projection shouldn’t I ?
But when I write :
http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&crs=EPSG:27572
I get :
java.lang.IllegalArgumentException: Bad value 226!
Le 12 déc. 07 à 12:08, Justin Deoliveira a écrit :
Hi Laurent,
feature type?
-Justin
“http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd”>
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
It’s the best place to buy or sell services for
Justin Deoliveira
Hmmm... not sure about this one. Is there any chance you can include the
entire stack trace. It should be on the console if running with jetty,
or in your servlet container logs.
-Justin
choose another projection shouldn't I ?
But when I write :
<http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&crs=EPSG:27572>
I get :
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
Hi Laurent,
feature type?
-Justin
<http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&srs=EPSG:27572>>
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
<mailto:Geoserver-users@lists.sourceforge.net>
Justin Deoliveira
!DSPAM:4007,475fc739319971336712104!
Justin Deoliveira
when the ‘ServiceExceptionReport’ is thrown nothing is modified in ‘/usr/local/apache-tomcat-6.0.10/logs’ …
But another strange thing is when I try to list the SRS in the entity manager I get :
GeoServer - Exception
The following exception was thrown:
org.geotools.factory.FactoryNotFoundException: Aucune fabrique de type “GeoserverCustomWKTFactory” n’a été trouvée.
Hum
Le 12 déc. 07 à 13:06, Justin Deoliveira a écrit :
Hmmm… not sure about this one. Is there any chance you can include the
-Justin
But when I write :
I get :
Hi Laurent,
feature type?
-Justin
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
Justin Deoliveira
Geoserver-users@anonymised.comsourceforge.net
Geoserver-users@anonymised.comurceforge.net
Justin Deoliveira
Are you sure that no logs are written to catalina.out? Perhaps they are
being buffered?
Well i dont have to speak french to know that there seems to be a
problem loading the geoserver wkt epsg factory.
Andrea: any ideas? I cant figure out much more without the entire
request log.
-Justin
when the 'ServiceExceptionReport' is thrown nothing is modified in
'/usr/local/apache-tomcat-6.0.10/logs' ...
manager I get :
"GeoserverCustomWKTFactory" n'a été trouvée.
Hum
-Justin
But when I write :
<http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&crs=EPSG:27572>>
I get :
<ServiceException>
</ServiceException>
Hi Laurent,
feature type?
-Justin
<http://localhost:8081/geoserver/wms/reflect?format=image/gif&layers=edfgeo:agenceedf2&srs=EPSG:27572>>>
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
Justin Deoliveira
Justin Deoliveira
!DSPAM:4007,475fe6dd32588992556831!
Justin Deoliveira
being buffered?
request log.
No, I don't know why the extension wkt factory cannot be loaded
(it's the one based on user defined srs types), that never
happened to me yet it's not the first user having troubles
with it... it's just that nobody reported enough info to
be able and track down the issue.
Btw, are the nightlies down?
the task I was given was specifically limited to cached bounds (which
are 4326 + native). Native can be used, provided that all requested
layers have the same bounds, otherwise it reverts to 4326 (and yells at
you if you explicitly provide something else).
Andrea: Is there an easy way to reproject the cached bounding box?
In the mean time Laurent will probably have to use the regular WMS.
-Arne
Arne Kepp wrote:
Sorry, what I meant was that all layers share the same native SRS.
-Arne
Ok thank you for your quick anwers
Laurent
Le 12 déc. 07 à 15:34, Arne Kepp a écrit :
-Arne
I've added the code, see http://jira.codehaus.org/browse/GEOS-1603
It will show up in the next nightly and RC2.
-Arne
Any ideas ?
Thanks
Laurent
geoserver 1.6.0-RC1
!DSPAM:4038,475fbf6a306198362916074!
