I believe that GeoNode is setting up its own user/role source when integrating with GeoServer,
so it may be that changing the GS config files does nothing.
Mind, this is just a hunch, there’s a good chance I’m wrong here
On Thu, Oct 2, 2014 at 10:13 AM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Lubomir
Quite strange. Please can you check if the value of
password=“crypt1:Z22ZwbZyJpL3kt3rZrM3PmY38jsMFYdx”
changes if you change the password of the admin user. (Note, the value change is independent of a password change because we use a salt. Saving the password “geoserver” two times will result into two different values).
Next, you can switch to the plain text password encoder (you have to change the settings in the default user/group service). Change the password and you should see the result in plain text
password=“plain:mynewpasswordf”
I think this is the best way to resolve the problem. (After resolving, switch back to the digest encoder).
Christian
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Oct 2, 2014 at 9:52 AM, Lubomir Filipov <lubomirfilipov@anonymised.com> wrote:
Hi Christian,
thanks for taking the time to reply.
This is the file you are referring to. We tried to disable the default admin user, but still we can login with the default password (and the geonode password as well). Geoserver version is 2.4 (the snapshot, used for Geonode 2.0). We tried with geoserver 2.5, but the result is the same. We tried on Ubuntu 12.4/12.5 and Debian, but the result is the same. We follow step by step the instruction of the geonode site.
![Inline image 1]()
We have made a detail movie of what/how we configure the system.
https://drive.google.com/file/d/0B2oRsQyYjsqyMnRFQnN5Vy1vS2c/edit?usp=sharing
I will appreciate any ideas and suggestions.
My very best,
Lubo.
DI Christian Mueller MSc (GIS), MSc (IT-Security)
OSS Open Source Solutions GmbH
Lubomir Filipov
48 Evlogi Georgiev Blvd,
1504 Sofia, Bulgaria
e-mail: lubomirfilipov@anonymised.com
cell phone: (+359) 888 972277
fax: (+359) 2 4916469**%202%204916469)**
skype name: fipeto
http://www.linkedin.com/in/lubomirfilipov
http://www.facebook.com/GAPconsult.bg
On Wed, Oct 1, 2014 at 12:03 PM, Christian Mueller <christian.mueller@anonymised.com> wrote:
Hi Lubomir
I assume you are talking about the password of the admin user.
Please take a look into
security/usergroup/default/users.xml
There is an XML element called with attributes name and password. What do you see ?
Christian
On Tue, Sep 30, 2014 at 8:37 PM, Lubomir Filipov <lubomirfilipov@anonymised.com> wrote:
Hello all,
we are running to a security problem using Geonode 2.0 and the default version of geoserver (part of the geonode instalation), which is 2.4.
The issues is place also on: https://github.com/GeoNode/geoserver-geonode-ext/issues/15 from January 2014.
The issue is that we cannot change the default password of geoserver (it allows change, but it keeps the old password as well).
Anyone running similar issue?
Thanks a lot in advance.
Lubomir Filipov
skype name: fipeto
