[Geoserver-users] reset the values of the property interpolation (app-schema.properties)
Hi
I wondered if and how it would be possible to reload or to dynamically
overwrite the property interpolation attributes from the
app-schema.properties file, without restarting.
Would it be possible via the rest api?
tx
Luc
View this message in context: http://osgeo-org.1560.x6.nabble.com/reset-the-values-of-the-property-interpolation-app-schema-properties-tp5168056.html
Luc,
I have never tried reloading app-schema sources even using the GUI; instead I reload the entire servlet or even restart tomcat.
The properties file is read at startup and should in theory be reloaded when data stores are reloaded. The problem is that, to orchestrate dependencies between types, app-schema uses a central registry. Correct reconstruction of this registry on partial reload is not supported and has has not been tested, as far as I know, so I expect problems.
What are you trying to do? Can it be achieved with CQL and database changes? This would seem in principle to be a much more robust way of modifying content. The app-schema.properties file exists to ease deployments by externalising deployment-specific information, not to modify a running deployment.
Kind regards,
Ben.
On 17/10/14 23:58, lucvanlinden wrote:
Hi
tx
Luc
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-users mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
