On Thu, Apr 2, 2015 at 11:17 AM, Luís de Sousa <luis.a.de.sousa@anonymised.com..>
wrote:
Before I go on with further changes to OpenLayers I would like to
understand why isn't the version attribute included in the
CoverageDescription element. Bug or feature?
Feature, the WCS 1.1.1 xml schemas have no version attribute (nor does
ows:DescriptionType):
<complexType name="CoverageDescriptionType">
<annotation>
<documentation>Full description of one coverage available from a WCS
server. This description shall include sufficient information to allow all
valid GetCoverage operation requests to be prepared by a WCS client.
</documentation>
</annotation>
<complexContent>
<extension base="ows:DescriptionType">
<sequence>
<element ref="wcs:Identifier">
<annotation>
<documentation>Unambiguous identifier of this coverage, unique for this WCS
server. </documentation>
</annotation>
</element>
<element ref="ows:Metadata" minOccurs="0" maxOccurs="unbounded">
<annotation>
<documentation>Optional unordered list of more metadata elements about this
coverage. A list of metadata elements for CoverageDescriptions could be
specified in a WCS Application Profile. </documentation>
</annotation>
</element>
<element name="Domain" type="wcs:CoverageDomainType"/>
<element name="Range" type="wcs:RangeType"/>
<element name="SupportedCRS" type="anyURI" minOccurs="0"
<annotation>
<documentation>Unordered list of references to all the coordinate reference
systems that may be referenced as the GridBaseCRS of a GridCRS specified in
the Output part of a GetCoverage operation request. The GridBaseCRS of the
GridCRS of a georectified offered coverage shall be listed as a
SupportedCRS. An ImageCRS for an unrectified offered image shall be listed
as a SupportedCRS, so that it may be referenced as the GridBaseCRS of a
GridCRS. This ImageCRS shall be the ImageCRS of that unrectified offered
image, or the ImageCRS that is referenced as the GridBaseCRS of the GridCRS
that is used by that unrectified offered image In addition, the
GetCoverage operation output may be expressed in the ImageCRS or GridCRS of
an unrectified offered coverage, instead of in a specified GridCRS. These
Supported¬CRSs can also be referenced in the BoundingBox in the
DomainSubset part of a GetCoverage request. </documentation>
</annotation>
</element>
<element name="SupportedFormat" type="ows:MimeType" maxOccurs="unbounded">
<annotation>
<documentation>Unordered list of identifiers of all the formats in which
GetCoverage operation responses can be encoded for this coverage.
</documentation>
</annotation>
</element>
</sequence>
</extension>
</complexContent>
</complexType>
Btw, nor does the current OGC schema at
http://schemas.opengis.net/wcs/1.1/wcsDescribeCoverage.xsd, nor does the
1.1.0 version as
far as I can see.
Could you do these check yourselves before asking others to do them fo you?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
