Hi Justin, hi list !
Thanks a for your last answer, it helped us to go forward in the process. We are close to a solution now.
We still get an error. You asked us to provide you with the entire stack trace.
After this command :
E:\MyFolder\Outils\Curl\curl_7.18.2>curl -u admin:geoserver -XPUT -H 'Content-type: application/zip' --data-binary @c:/pampers.zip http://localhost:8081/geoserver/rest/workspaces/julien/datastores/pampers/file.shp
I got this stack trace :
02 juil. 09:30:13 INFO [catalog.rest] - PUT file, mimetype: application/x-www-form-urlencoded
02 juil. 09:30:13 INFO [catalog.rest] - Using existing datastore: pampers
02 juil. 09:30:13 WARN [shapefile.sh] - Could not open the .shx file, continuing assuming the .shp file is not sparse
java.io.FileNotFoundException: C:\Serveurs\apache-tomcat-6.0.18\webapps\geoserver\data\data\pampers\pampers.shx
at org.geotools.data.shapefile.ShpFiles.getReadChannel(ShpFiles.java:821)
at org.geotools.data.shapefile.shp.IndexFile.<init>(IndexFile.java:78)
at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:162)
at org.geotools.data.shapefile.ShapefileDataStore.openShapeReader(ShapefileDataStore.java:425)
at org.geotools.data.shapefile.ShapefileDataStore.readAttributes(ShapefileDataStore.java:652)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:610)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:604)
at org.geotools.data.shapefile.ShapefileDataStore.getFeatureSource(ShapefileDataStore.java:959)
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:263)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:640)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
02 juil. 09:30:13 ERROR [geoserver.rest] -
java.lang.RuntimeException: java.io.IOException: Wrong magic number, expected 9994, got 1347093252
at org.geoserver.catalog.rest.DataStoreFileResource.handlePut(DataStoreFileResource.java:295)
Caused by: java.io.IOException: Wrong magic number, expected 9994, got 1347093252
at org.geotools.data.shapefile.shp.ShapefileHeader.checkMagic(ShapefileHeader.java:53)
at org.geotools.data.shapefile.shp.ShapefileHeader.read(ShapefileHeader.java:75)
at org.geotools.data.shapefile.shp.ShapefileReader.readHeader(ShapefileReader.java:206)
at org.geotools.data.shapefile.shp.ShapefileReader.init(ShapefileReader.java:255)
at org.geotools.data.shapefile.shp.ShapefileReader.<init>(ShapefileReader.java:168)
... 55 more
It seems GeoServer treat my zip file as a shape file, and does not unzip it.
My data directory structure looks like:
<root>/data/pampers/pampers.shp
but pampers.shp is actually a zip archive
All the files are at the root of the archive. The zip file look like :
- pampers.dbf
- pampers.fix
- pampers.prj
- pampers.qix
- pampers.shp
- pampers.shx
Do you see anything that appears to be wrong ?
Thanks in advance for your support.
Gilles
-----Message d'origine-----
De : Justin Deoliveira [mailto:jdeolive@anonymised.com]
Envoyé : jeudi 2 juillet 2009 07:40
À : TASSE Gilles
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] [REST]
TASSE Gilles wrote:
Hello,
I'm still having problems with adding layers to Geoserver using REST API.
I'm triying to explain my problem.First, I created the workspace with :
curl -u user:pwd -v -XPOST -H "Content-type: text/xml" -d "<workspace><name>test</name></workspace>" http://localhost:8081/geoserver/rest/workspaces
It looked to be OK !
Then, I tried to put the zip file (pamper.zip, containing all shp, prj and other required files) with the following command
curl -u admin:geoserver -XPUT -H 'Content-type: application/zip' --data-binary @c:/pampers.zip http://localhost:8081/geoserver/rest/workspaces/test/datastores/pampers/file.shp
But I got :
Hmmm... do you have the entire stack trace? It would be helpful to know
exactly where this is occuring. You may have to turn logging up, go to
the web ui and turn up logging to GEOSERVER_DEVELOPER_LOGGING.
But yeah, seems something is getting mixed up trying to read a shapefile
that is not actually a shapefile.
So you say that your data directory structure looks like:
<root>/data/pampers/pampers.shp?
Curious, what does the structure of the zip file look like? Are all the
files at the root of the archive?
-Justin
It seems to be as if Geoserver has treated my zip file as a shape file, because a "pampers" directory was created in my " geoserver\data\data\" directory, but there is only one file in there : pampers.shp that has the same size of the original zip file.
What's wrong in my code ?
thanks in advance
Envoyé : mercredi 1 juillet 2009 07:10
À : TASSE Gilles
Objet : Re: [Geoserver-users] [REST]Hi,
There are some docs available here:
http://docs.geoserver.org/1.7.x/user/extensions/rest/index.html
In particular some examples that use curl here:
http://docs.geoserver.org/1.7.x/user/extensions/rest/rest-config-examples-curl.html
And finally there are some scripts which build up the regular geoserver
release directory from scratch, including the states layer. YOu can find
those here:http://svn.codehaus.org/geoserver/branches/1.7.x/src/extension/restconfig/scripts/
Hope that helps.
-Justin
TASSE Gilles wrote:
We are trying to understand how to use the REST API to add layers. Could
you give us an example of the url we should enter to add a datastore
with one of the sample files (let's say states.shp) ?All our tries have returned us a 405 error.
Thank you !
*Gilles Tasse*
/2, rue Antoine Becquerel/
/35700 RENNES/
/mailto:gilles.tasse@anonymised.com <mailto:nelly.hascoet@anonymised.com>/
/Tél : 02.23.21.11.11 - Fax : 02.23.21.11.00/------------------------------------------------------------------------
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
