[Geoserver-users] REST API and PUT updates
Hello All,
I’ve been using the REST API lately, which has been a bit problematic for me.
Is there a way to change a single parameter for an object from a single REST call? For example, change the database name for a data store?
I suppose what I’m after is PATCH rather than PUT, as PUT is supposed to be atomic.
At the moment it looks like you would have to:
  1. Do a GET to get the current config
  2. Load the response to a data structure
  3. Merge the response with your desired change (this would be a lot easier if the JSON was standard key:value)
  4. Do a PUT to make the merged change active
    As I said I can see why PUT shouldn’t do this, but to show what I mean here is an example of it not working from a PUT:
Say I’ve got a datastore:
curl -u admin:geoserver -GET http://192.168.2.237:8080/geoserver/rest/workspaces/tester/datastores/Test.xml
Test PostGIS true tester public postgres crypt1:mWGfLiNZL8UOZCpLkRE7mw== localhost [http://james](http://james) postgres <__default>true
Then I want to change the database name from ‘postgres’ to ‘postgres-test’, so I sent the following XML in a PUT request:
Test PostGIS postgres-test /connectionParameters>
But this removes the other config:
Test PostGIS true tester postgres-test <__default>true
James Sewell,
PostgreSQL Team Lead / Solutions Architect
Level 2, 50 Queen St, Melbourne VIC 3000
P (+61) 3 8370 8000 W www.lisasoft.com F (+61) 3 8370 8099
If I remember the code both POST and PUT are supported. Patch grabs the existing catalog item, applies the change to it, and saves…
https://github.com/geoserver/geoserver/blob/master/src/restconfig/src/main/java/org/geoserver/catalog/rest/FeatureTypeResource.java#L87
On 6 July 2016 at 17:16, James Sewell <james.sewell@anonymised.com> wrote:
Hello All,
James Sewell,
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
Attend Shape: An AT&T Tech Expo July 15-16. Meet us at AT&T Park in San
Francisco, CA to explore cutting-edge tech and listen to tech luminaries
present their vision of the future. This family event has something for
everyone, including kids. Get more information and register today.
http://sdm.link/attshape
Geoserver-users mailing list
Jody Garnett
