So I've just imported a large number of geotiff files that are grouped
logically on the file system by resolution (1:2M, 1:1M, 1:250K, etc)
Since the volume is high, I want to use the REST api to create a layer
group, One for each resolution set.
I've found this
http://docs.geoserver.org/stable/en/user/rest/examples/curl.html#creating-a-layer-group
but it doesn't provide the complete syntax for referencing a raster
layer set, workspace, coordinate reference system, output formats,
gridsets etc.
Are there additional examples, documentation or a scheme file for
defining what the request needs to look like for creating a layer
group?
Hi Alex,
from what I have learned how people usually work with REST API is that they do what they want on a small scale using the web GUI and then do a GET request using the XML format. The XML returned usually is in the exact format a PUT request needs.
So, make one small layer group, GET it via REST and use that as a template for your PUT requests.
I've found this
gridsets etc.
group?
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-users mailing list
Peter Kovac
IMS Programmer
MicroStep-MIS
peter.kovac@anonymised.com
Thanks Peter. Unfortunately, my UI created layer group doesn't show up
anywhere in the rest interface. Very odd....
On Wed, Jan 13, 2016 at 11:30 AM, Peter Kovac
<peter.kovac@anonymised.com> wrote:
Hi Alex,
I've found this
gridsets etc.
group?
Peter Kovac
IMS Programmer
MicroStep-MIS
