[Geoserver-users] REST API - GET results appear wrong
Hi List,
On a 2.7.1 install, the REST API is giving what appear to be anomalous results.
A GET request to …/rest/layers correctly lists all of the layers on the instance.
But
/rest/layergroups and /rest/styles both return empty lists despite there being lots of both of them.
Further confusion:
/styles(.html) = no results (and an empty html page source)
/styles.json|xml = 10 results (both giving the same 10) - there are over 100 styles on the server.
/layergroups returns empty across all three formats.
Any thoughts on what’s going on? Is there a reason they wouldn’t be listed? The docs don’t suggest any.
Jonathan
Permissions? failing that turn logging up and see what shows up
curl -u admin:geoserver -v http://localhost:4080/geoserver/rest/styles.json
and
both work fine for me on a vanilla 2.8.1 install as do the layergroups ones too.
Ian
On 11 February 2016 at 15:35, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi List,
But
Further confusion:
Jonathan
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ian Turton
Adding to Ian’s, I’ve just tried the same requests against a vanilla 2.7.1 installation and they return correct results.
Maybe there is something wrong with your data dir? Do you see any errors in the log?
On Thu, Feb 11, 2016 at 4:46 PM, Ian Turton <ijturton@anonymised.com…84…> wrote:
and
Ian
Hi List,
But
Further confusion:
Jonathan
Ian Turton
Best regards,
Stefano Costa
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Dott. Stefano Costa
Senior Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:     +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility  for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Hi Ian,
There are no permissions set on anything, so not that I’m afraid.
The logs for a /rest/layergroups request show this (GeoServer Debug level):
12 Feb 15:58:32 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/layergroups’; to: ‘/rest/layergroups’ and httpMethod= GET
12 Feb 15:58:32 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
12 Feb 15:58:32 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/layergroups’; antPath is /**; matchedPath=true; matchedMethods=true
12 Feb 15:58:32 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
12 Feb 15:58:32 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/layergroups]
12 Feb 15:58:32 DEBUG [org.geoserver] - Thread 40 locking in mode READ
12 Feb 15:58:32 DEBUG [org.geoserver] - Thread 40 got the lock in mode READ
12 Feb 15:58:32 DEBUG [org.geoserver.catalog.rest] - in workspace null
12 Feb 15:58:32 DEBUG [org.geoserver] - Thread 40 releasing the lock in mode READ
12 Feb 15:58:32 DEBUG [org.geoserver.filters] - Compressing output for mimetype: text/html
12 Feb 15:58:32 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
GeoTools debug level is completely empty for a rest/layergroups request
And the /rest/styles request shows an exception (geoserver debug):
12 Feb 15:59:28 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/rest/styles’; to: ‘/rest/styles’ and httpMethod= GET
12 Feb 15:59:28 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [GET]
12 Feb 15:59:28 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/rest/styles’; antPath is /**; matchedPath=true; matchedMethods=true
12 Feb 15:59:28 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - returning ADMIN
12 Feb 15:59:28 TRACE [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/rest/styles]
12 Feb 15:59:28 DEBUG [org.geoserver] - Thread 153 locking in mode READ
12 Feb 15:59:28 DEBUG [org.geoserver] - Thread 153 got the lock in mode READ
12 Feb 15:59:28 DEBUG [org.geoserver.catalog.rest] - GET styles
12 Feb 15:59:28 DEBUG [org.geoserver] - Thread 153 releasing the lock in mode READ
12 Feb 15:59:28 ERROR [org.geoserver.rest] - Exception intercepted
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:162)
at org.geoserver.rest.format.ReflectiveHTMLFormat$ObjectToMapWrapper.wrap(ReflectiveHTMLFormat.java:288)
at freemarker.ext.beans.BeanModel.wrap(BeanModel.java:325)
at freemarker.ext.beans.IteratorModel.next(IteratorModel.java:134)
at freemarker.core.IteratorBlock$Context.runLoop(IteratorBlock.java:164)
at freemarker.core.Environment.visit(Environment.java:428)
at freemarker.core.IteratorBlock.accept(IteratorBlock.java:102)
at freemarker.core.Environment.visit(Environment.java:221)
at freemarker.core.MixedContent.accept(MixedContent.java:92)
at freemarker.core.Environment.process(Environment.java:199)
at freemarker.template.Template.process(Template.java:237)
at org.restlet.ext.freemarker.TemplateRepresentation.write(TemplateRepresentation.java:112)
at com.noelios.restlet.http.HttpServerCall.writeResponseBody(HttpServerCall.java:342)
at com.noelios.restlet.http.HttpServerCall.sendResponse(HttpServerCall.java:306)
at com.noelios.restlet.ext.servlet.ServletCall.sendResponse(ServletCall.java:306)
at org.geoserver.rest.GeoServerServletConverter.commit(GeoServerServletConverter.java:54)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:130)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:620)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:76)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1040)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor469.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:159)
… 105 more
Caused by: java.io.IOException: No such resource: OS VectorMap Local - Areas.sld
at org.geoserver.config.GeoServerDataDirectory.parsedStyle(GeoServerDataDirectory.java:1227)
at org.geoserver.catalog.ResourcePool.getStyle(ResourcePool.java:1746)
at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:102)
at sun.reflect.GeneratedMethodAccessor242.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:146)
at $Proxy10.getStyle(Unknown Source)
… 109 more
12 Feb 15:59:28 DEBUG [org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1] - SecurityContextHolder now cleared, as request processing completed
---- On Thu, 11 Feb 2016 15:46:35 +0000 Ian Turton<ijturton@anonymised.com.> wrote ----
and
Ian
Hi List,
But
Further confusion:
Jonathan
Ian Turton
