Thanks
I try the PUT with this body
“updateMode”: “APPEND”,
“layer”: {
“name”: “layerA”,
“nativeName”: “layerA”
I receive a 500 error with the message ‘updateMode’
I’m using geoserver 2.10.1
for layer REST representation do you mean the response of these?
http://10.23.8.193:8080/geoserver/rest/layers/layerA.html
Thanks
Giuseppe
Il giorno lun 23 mag 2022 alle ore 11:20 Andrea Aime <andrea.aime@anonymised.com> ha scritto:
Hi Giuseppe,
close, but your JSON is one level off, you’re updating the task, so it’s the top level object in the request.
So it would be something like this:
“layer”: {
“name”: “layerA”
Checking a REST script I have handy, inside the layer I also have “nativeName” : “theNativeName” (check the value for nativeName from the layer REST representation).
On Mon, May 23, 2022 at 11:05 AM Giuseppe Falcone <falcone.giuseppe@anonymised.com> wrote:
Thanks a lot Andrea for the response, but I’m not able to do that
POST http://10.23.8.193:8080/geoserver/rest/import to create task import
POST http://10.23.8.193:8080/geoserver/rest/import//task to upload shapefile zip (multipart form-data)
What is the body of PUT request /geoserver/rest/imports//tasks/ to change target layer name?
I try:
“task”:{
“id”: 0,
“href”: “http://10.23.8.193:8080/geoserver/rest/imports/24/tasks/0”,
“layer”: {
“name”: “layerA”
(layerA is a layer on geoserver, on same workspace and same datastore having same fields of uploaded shapefile)
But I receive error “Cannot cast org.geoserver.importer.ImportTask to org.geoserver.catalog.StoreInfo”
Thanks a lot
Giuseppe
Il giorno dom 22 mag 2022 alle ore 17:17 Andrea Aime <andrea.aime@anonymised.com> ha scritto:
On Thu, May 19, 2022 at 9:47 AM Giuseppe Falcone <falcone.giuseppe@anonymised.com> wrote:
Thanks for you response.
I rephrase the question:
I have a web application where a user uploads a shapefile and this needs to be inserted into a postgis table that has the same fields (in append mode). Shapefile and table don’t necessarily have the same name.
There is a manner to execute this task via rest api or importer api?
Use the REST API:
- Set up the context and the shapefile to import
- Use PUT requests against the context to update the import mode (APPEND) and change the target layer name (to the one you want to append to)
- Run the import.
CheersAndrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
