On Tue, Aug 16, 2016 at 11:52 AM, Andrea Aime <andrea.aime@anonymised.com.1107…> wrote:
yep… the original design concept of layers and resources was quite a bit different from what we have today,
and in that, it made sense not to qualify the layers by workspace (we were supposed to have a concept of “Map”
that would have held layers, and no global layers, but that that never materialized), but with today’s arrangement it’s a problem.
Imho it would make more sense to have the list of layers inside each workspace instead, of course that would cause
backwards compatibility issues, but for some time I guess we could simply have both, and qualify the ones at the global level.
Anyways, just my opinion, it’s probably something worth discussing in the devel list once there are funds to tackle it.
In the meantime I’d open a bug report here (adding the prefix in the name element is not that hard, what I describe above
is certanly more work instead):
https://osgeo-org.atlassian.net/projects/GEOS/summary
On Tue, Aug 16, 2016 at 11:42 AM, Alessandro Pasotti <apasotti@anonymised.com> wrote:
Thanks for your answer, but I’m afraid I’ve found a bug in 2.9:
I’ve configured two layers with the same name ‘roads’ in two different ws: ‘sf’ and ‘sf2’, this is what I get from
http://localhost:8080/geoserver/rest/layers.xml
roads
roads
there is no way to tell them apart
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
On Tue, Aug 16, 2016 at 11:25 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ciao Alessandro,
looking at how the code works, I’d say access via qualified name ought to be working
for all types of requests.
I have tried only with GET, that seems to work as expected.
Let us know if it works out well for you
Alessandro Pasotti
w3: www.itopen.it
On Tue, Aug 16, 2016 at 10:16 AM, Alessandro Pasotti <apasotti@anonymised.com> wrote:
I believe this is a known limitation of the REST API, but I wonder if is there any way to overcome this limitation with some parsing of the XML results.
You can probably prefix the layers names with the ws to get the layer details from the REST API but I don’t know if that would allow you to also interact with the individual ws-prefixed layer (add/remove styles etc.).
Am I trying to do something that is currently not possible at all?
Alessandro Pasotti
w3: www.itopen.it
Geoserver-users mailing list
Geoserver-users@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Alessandro Pasotti
w3: www.itopen.it
