[Geoserver-users] REST API Question
Hi list,
I'm wondering if anyone knows or if it's possible to get information about where's a layer stored via REST API. For example, I'd like to know, based on a layer name, the server and the DB where it's stored.
If not, how could I achieve this? Any ideas?
Thanks in advance.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda@anonymised.com | www.hazi.eus
T 945 003 240 - M 627 923 170 - F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
On Thu, Sep 1, 2016 at 11:47 AM, David Alda Fernandez de Lezea <
dalda@anonymised.com> wrote:
Hi list,
From the layer, follow up to the resource, and then to the store, you have
the connection information there (so, three separate REST calls).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Thanks for your response! Easier than I thought. I’ll try it.
Agur bero bat,
dalda@...6818... | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
De: andrea.aime@...84... [mailto:andrea.aime@…84…] En nombre de Andrea Aime
Enviado el: jueves, 01 de septiembre de 2016 14:06
Para: David Alda Fernandez de Lezea
CC: GeoServer Users
Asunto: Re: [Geoserver-users] REST API Question
On Thu, Sep 1, 2016 at 11:47 AM, David Alda Fernandez de Lezea <dalda@...6818...> wrote:
Hi list,
From the layer, follow up to the resource, and then to the store, you have the connection information there (so, three separate REST calls).
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
