[Geoserver-users] REST API reload not reloading gwc-gs.xml
I’m using GeoServer 2.3.0 with GeoWebCache 1.4.
I realised that reloading the configuration via the REST API [1] does not reload the settings configured in gwc-gs.xml
This seems to be done only on GeoServer startup, cf. the log line:
INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
Is it intended that this is not included in the configuration reload but only on startup? Or is it a bug?
I’d like to be able to change settings in gwc-gs.xml and reload them without the need to restart the entire GeoServer.
Thanks for your help and best regards,
Matthias
[1] - http://docs.geoserver.org/stable/en/user/rest/api/reload.html
On Wed, Feb 11, 2015 at 12:32 PM, Matthias Uden <matthias.uden@anonymised.com>
wrote:
I'm using GeoServer 2.3.0 with GeoWebCache 1.4.
gwc-gs.xml
Hum... take your pick :slight_smile:
GWC is indeed a separate application, that can be made to run inside
GeoServer with some glue,
mostly a bunch of listeners that the GWC integration classes in gs-gwc use
to inform GeoWebCache
about changes in the GeoServer configuration.
I see the listener for the reload event, but it's just reloading the tile
layers from the catalog, not
reloading the gws-gs.xml file... honestly, not sure how easy/feasible that
is, but I'd open
a ticket at
http://jira.codehaus.org/browse/GEOS
Chers
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Andrea,
thanks a lot for your answer! I think if it is technically possible and reasonable, the gwc-gs.xml should be reloaded as well.
Unless there is any concrete reason for this not being possible from a development point-of-view, that is.
Thanks, I'd gladly open an issue on the JIRA, if I could.. But I have no account.
Could either you open a ticket for this yourself or alternatively grant me access to that JIRA?
Many thanks,
Matthias
On 12.02.2015 09:20, Andrea Aime wrote:
On Wed, Feb 11, 2015 at 12:32 PM, Matthias Uden <matthias.uden@anonymised.com <mailto:matthias.uden@anonymised.com>> wrote:
GWC is indeed a separate application, that can be made to run inside GeoServer with some glue,
mostly a bunch of listeners that the GWC integration classes in gs-gwc use to inform GeoWebCache
I see the listener for the reload event, but it's just reloading the tile layers from the catalog, not
reloading the gws-gs.xml file... honestly, not sure how easy/feasible that is, but I'd open
a ticket at
Chers
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Thu, Feb 12, 2015 at 9:30 AM, Matthias Uden <matthias.uden@anonymised.com>
wrote:
Hi Andrea,
account.
Getting a login there is indeed not intuitive, but if you look at the page
I've linked, there
are instructions on how to do so in the project description, top left:
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea,
thanks, I missed that explanation how to create an account.
I was able to do so now and create an issue in the JIRA:
https://jira.codehaus.org/browse/GEOS-6880
Let's see if anyone can contribute to this issue.
Matthias
On 12.02.2015 09:53, Andrea Aime wrote:
On Thu, Feb 12, 2015 at 9:30 AM, Matthias Uden <matthias.uden@anonymised.com <mailto:matthias.uden@anonymised.com>> wrote:
    Hi Andrea,
    have no account.
Getting a login there is indeed not intuitive, but if you look at the page I've linked, there
Ing. Andrea Aime
@geowolf
Technical Lead
