[Geoserver-users] REST API reload not reloading gwc-gs.xml
What if the location of cache directory is defined in web.xml? Should configuration from alt_dir/geowebcache.xml be reloaded as well?
GEOWEBCACHE_CACHE_DIR
alt_dir
-Jukka Rahkonen-
Matthias Uden wrote:
Hi Andrea,
thanks a lot for your answer! I think if it is technically possible and reasonable, the gwc-gs.xml should be reloaded as well.
Unless there is any concrete reason for this not being possible from a development point-of-view, that is.
Thanks, I’d gladly open an issue on the JIRA, if I could… But I have no account.
Could either you open a ticket for this yourself or alternatively grant me access to that JIRA?
Many thanks,
Matthias
On 12.02.2015 09:20, Andrea Aime wrote:
On Wed, Feb 11, 2015 at 12:32 PM, Matthias Uden <matthias.uden@…84…> wrote:
I’m using GeoServer 2.3.0 with GeoWebCache 1.4.
I realised that reloading the configuration via the REST API [1] does not reload the settings configured in gwc-gs.xml
This seems to be done only on GeoServer startup, cf. the log line:
INFO [gwc.config] - Initializing GeoServer specific GWC configuration from gwc-gs.xml
Is it intended that this is not included in the configuration reload but only on startup? Or is it a bug?
Hum… take your pick :slight_smile:
GWC is indeed a separate application, that can be made to run inside GeoServer with some glue,
mostly a bunch of listeners that the GWC integration classes in gs-gwc use to inform GeoWebCache
about changes in the GeoServer configuration.
I see the listener for the reload event, but it’s just reloading the tile layers from the catalog, not
reloading the gws-gs.xml file… honestly, not sure how easy/feasible that is, but I’d open
a ticket at
http://jira.codehaus.org/browse/GEOS
Chers
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
