[Geoserver-users] REST API sld upload strange behaviour
Hello All,
I am doing a fairly simple thing but it doesn’t quite seem to work as expected.
I am creating a new empty style and then uploading a local sld into it (all via the rest api).
The problem I am seeing is that there are certain xmlns objects being stripped out - and thus breaking the sld.
The commands I am using;
curl -v -u admin:geoserver -XPOST -H “Content-type: text/xml” -d “topoareatopoarea.sld” http://localhost:8080/geoserver/rest/styles
curl -v -u admin:geoserver -XPUT -H “Content-type: application/vnd.ogc.sld+xml” -d @styles/topoareamin.sld http://localhost:8080/geoserver/rest/styles/topoarea
The sld in questions is below and the bit that gets stripped out is the se bit (in bold).
If I copy and paste this into the geoserver gui it works fine.
Any help would be much appreciated.
Toby
<StyledLayerDescriptor xmlns=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.1.0” xmlns:xlink=“http://www.w3.org/1999/xlink” xsi:schemaLocation=“http://www.opengis.net/sld http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsdxmlns:se=“http://www.opengis.net/se>
se:Nametopographicarea</se:Name>
se:FeatureTypeStyle
se:Rule
se:Name</se:Name>
se:PolygonSymbolizer
se:Fill
<se:SvgParameter name=“fill”>#ccff99</se:SvgParameter>
</se:Fill>
</se:PolygonSymbolizer>
</se:Rule>
se:Rule
se:NameBuilding</se:Name>
se:Description
se:TitleBuilding</se:Title>
se:AbstractBuildings</se:Abstract>
</se:Description>
<ogc:Filter xmlns:ogc=“http://www.opengis.net/ogc”>
ogc:PropertyIsEqualTo
ogc:PropertyNamefeaturecode</ogc:PropertyName>
ogc:Literal10021</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
se:Fill
<se:SvgParameter name=“fill”>#ffd8b0</se:SvgParameter>
</se:Fill>
</se:Rule>
</se:FeatureTypeStyle>
Hi Toby,
I believe you’re using the wrong Content-type in your second request (PUT method), see: http://docs.geoserver.org/2.6.x/en/user/rest/api/styles.html#rest-api-styles-post-put
Since you’re clearly posting an SLD 1.1 / SE 1.1 document, you should:
  1. specify the SLD version in the first request by adding 1.1.0 to the content (POST)
  2. set the Content-type header to application/vnd.ogc.se+xml in the second request (PUT)
However, I tried to issue your requests with the correct SLD version / mime type against GS version 2.6.2, 2.7.1 and 2.8-SNAPSHOT (nightly build dated June 6th), and the most I could get inside the topoarea.sld file is:
<sld:StyledLayerDescriptor xmlns:xs="[http://www.w3.org/2001/XMLSchema](http://www.w3.org/2001/XMLSchema)"
xmlns:se="[http://www.opengis.net/se](http://www.opengis.net/se)" xmlns:gml="[http://www.opengis.net/gml](http://www.opengis.net/gml)"
xmlns:ogc="[http://www.opengis.net/ogc](http://www.opengis.net/ogc)" xmlns:sld="[http://www.opengis.net/sld](http://www.opengis.net/sld)">
	org.geotools.styling.StyledLayerDescriptorImpl@anonymised.com
</sld:StyledLayerDescriptor>
So, xmlns attributes are no longer stripped out, but there is likely a bug in the serialization of the created StyledLayerDescriptorImpl instance.
The problem seems to occur only if the style is created through the REST interface.
Has anybody else had any success creating SLD 1.1 / SE 1.1 via REST?
Il giorno lun, 01/06/2015 alle 11.27 +0100, Tobias Reinicke ha scritto:
Hello All,
Toby
se:FeatureTypeStyle
se:Rule
se:Name</se:Name>
se:Fill
</se:Fill>
</se:Rule>
se:Rule
se:Description
</se:Description>
</ogc:Filter>
se:Fill
</se:Fill>
</se:Rule>
Geoserver-users mailing list
[Geoserver-users@lists.sourceforge.net](mailto:Geoserver-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-users](https://lists.sourceforge.net/lists/listinfo/geoserver-users)
<br>-- <br><br>Best regards,<br>Stefano Costa<br><br>==<br>GeoServer Professional Services from the experts! Visit<br>http://goo.gl/it488V for more information.<br>==<br>Dott. Stefano Costa<br>Senior Software Engineer<br><br>GeoSolutions S.A.S.<br>Via Poggio alle Viti 1187<br>55054 Massarosa (LU)<br>Italy<br>phone: +39 0584 962313<br>fax: +39 0584 1660272<br><br>http://www.geo-solutions.it<br>http://twitter.com/geosolutions_it<br><br>-------------------------------------------------------<br>AVVERTENZE AI SENSI DEL D.Lgs. 196/2003<br>Le informazioni contenute in questo messaggio di posta elettronica e/o<br>nel/i file/s allegato/i sono da considerarsi strettamente riservate.<br>Il loro utilizzo è consentito esclusivamente al destinatario del<br>messaggio, per le finalità indicate nel messaggio stesso. Qualora<br>riceviate questo messaggio senza esserne il destinatario, Vi preghiamo<br>cortesemente di darcene notizia via e-mail e di procedere alla<br>distruzione del messaggio stesso, cancellandolo dal Vostro sistema.<br>Conservare il messaggio stesso, divulgarlo anche in parte,<br>distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità<br>diverse, costituisce comportamento contrario ai principi dettati dal<br>D.Lgs. 196/2003.<br><br>The information in this message and/or attachments, is intended solely<br>for the attention and use of the named addressee(s) and may be<br>confidential or proprietary in nature or covered by the provisions of<br>privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New<br>Data Protection Code).Any use not in accord with its purpose, any<br>disclosure, reproduction, copying, distribution, or either<br>dissemination, either whole or partial, is strictly forbidden except<br>previous formal approval of the named addressee(s). If you are not the<br>intended recipient, please contact immediately the sender by<br>telephone, fax or e-mail and delete the information in this message<br>that has been received in error. The sender does not give any warranty<br>or accept liability as the content, accuracy or completeness of sent<br>messages and accepts no responsibility for changes made after they<br>were sent or for other risks which arise as a result of e-mail<br>transmission, viruses, etc.<br><br><br><br>
Hi Stefano,
Thank you - that has actually worked fine for me (using my whole sld file) which is available here for your tests; (http://www.ordnancesurvey.co.uk/docs/styled-layer-descriptors/topography-sld.zip)
Full commands are now;
curl -v -u admin:geoserver -XPOST -H “Content-type: text/xml” -d “topoareatopoarea.sld1.1.0” http://localhost:8080/geoserver/rest/styles
curl -v -u admin:geoserver -XPUT -H “Content-type: application/vnd.ogc.se+xml” -d @styles/topoarea.sld http://localhost:8080/geoserver/rest/styles/topoarea
Thanks for your help.
Toby
On 3 June 2015 at 10:29, Stefano Costa <stefano.costa@anonymised.com> wrote:
Hi Toby,
  2. set the Content-type header to application/[vnd.ogc.se](http://vnd.ogc.se)+xml in the second request (PUT)
Hello All,
Toby
se:FeatureTypeStyle
se:Rule
se:Name</se:Name>
se:Fill
</se:Fill>
</se:Rule>
se:Rule
se:Description
</se:Description>
</ogc:Filter>
se:Fill
</se:Fill>
</se:Rule>
<br>-- <br><br>Best regards,<br>Stefano Costa<br><br>==<br>GeoServer Professional Services from the experts! Visit<br>[http://goo.gl/it488V](http://goo.gl/it488V) for more information.<br>==<br>Dott. Stefano Costa<br>Senior Software Engineer<br><br>GeoSolutions S.A.S.<br>Via Poggio alle Viti 1187<br>55054 Massarosa (LU)<br>Italy<br>phone: +39 0584 962313<br>fax: +39 0584 1660272<br><br>[http://www.geo-solutions.it](http://www.geo-solutions.it)<br>[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)<br><br>-------------------------------------------------------<br>AVVERTENZE AI SENSI DEL D.Lgs. 196/2003<br>Le informazioni contenute in questo messaggio di posta elettronica e/o<br>nel/i file/s allegato/i sono da considerarsi strettamente riservate.<br>Il loro utilizzo è consentito esclusivamente al destinatario del<br>messaggio, per le finalità indicate nel messaggio stesso. Qualora<br>riceviate questo messaggio senza esserne il destinatario, Vi preghiamo<br>cortesemente di darcene notizia via e-mail e di procedere alla<br>distruzione del messaggio stesso, cancellandolo dal Vostro sistema.<br>Conservare il messaggio stesso, divulgarlo anche in parte,<br>distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità<br>diverse, costituisce comportamento contrario ai principi dettati dal<br>D.Lgs. 196/2003.<br><br>The information in this message and/or attachments, is intended solely<br>for the attention and use of the named addressee(s) and may be<br>confidential or proprietary in nature or covered by the provisions of<br>privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New<br>Data Protection Code).Any use not in accord with its purpose, any<br>disclosure, reproduction, copying, distribution, or either<br>dissemination, either whole or partial, is strictly forbidden except<br>previous formal approval of the named addressee(s). If you are not the<br>intended recipient, please contact immediately the sender by<br>telephone, fax or e-mail and delete the information in this message<br>that has been received in error. The sender does not give any warranty<br>or accept liability as the content, accuracy or completeness of sent<br>messages and accepts no responsibility for changes made after they<br>were sent or for other risks which arise as a result of e-mail<br>transmission, viruses, etc.<br><br><br><br>
Apologies - those aren’t the right SLD’s. I’ll send the right link when I find it.
Toby
On 3 June 2015 at 11:06, Tobias Reinicke <ramotswa@anonymised.com> wrote:
Hi Stefano,
Toby
Hi Toby,
Hello All,
Toby
se:FeatureTypeStyle
se:Rule
se:Name</se:Name>
se:Fill
</se:Fill>
</se:Rule>
se:Rule
se:Description
</se:Description>
</ogc:Filter>
se:Fill
</se:Fill>
</se:Rule>
Hi Toby,
Il giorno mer, 03/06/2015 alle 11.06 +0100, Tobias Reinicke ha scritto:
Hi Stefano,
Super-glad to hear that! :slight_smile:
...and thanks for the test data!
You're welcome!
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
