[Geoserver-users] REST API URL
Hello,
I am trying to get the URL for a layer I created but I get the following error:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
Unable to match requested TILEMATRIXSET EPSG3857 to those supported by layer
I have tried to find answers but was unable to make anything work.
This is my geowebcache.xml if that is helpful.
1.20.0120EPSG38573857-2.003750834E7-2.003750834E72.003750834E72.003750834E7false156543.0339062578271.51695312539135.758476562519567.879238281259783.9396191406254891.96980957031252445.98490478515621222.9924523925781611.4962261962891305.74811309814453152.8740565490722676.4370282745361338.21851413726806619.1092570686340339.5546285343170171.02.8E-4EPSG3857:0EPSG3857:1EPSG3857:2EPSG3857:3EPSG3857:4EPSG3857:5EPSG3857:6EPSG3857:7EPSG3857:8EPSG3857:9EPSG3857:10EPSG3857:11EPSG3857:12EPSG3857:13EPSG3857:14256256false
Any help would be appreciated.
Thanks!
Andrew
There is no layer specified within that geowebcache.xml. The «layers» element right at the end of the document is empty. Maybe that is your problem.
Roar Brænden
fre. 20. mai 2022 kl. 01:39 skrev Andrew Coyne <acoyne@anonymised.com>:
Hello,
Thanks!
Andrew
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Thanks for the response Roar!
Do you have an example of the geowebcache.xml looks like with a layer added to it?
Andrew
Roar Brænden
fre. 20. mai 2022 kl. 01:39 skrev Andrew Coyne <acoyne@…11459…>:
Hello,
Thanks!
Andrew
