[Geoserver-users] REST Configuration API
Justin,
I also noticed that while the API provides good docs on how data can be
retrieved, but is there more examples of how to POST content?
I saw the CURL examples...but I'm wondering about coverages and
layers...which parameters are required? Which ones aren't?
Is there any other documentation I can read regarding that?
Ronak
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, March 31, 2009 11:51 AM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST Configuration API
Well the connectionParameters will be open ended. So I suggest just
making its content extensible, perhaps making it xs:any or something.
Also there is a bug in the current encoding so it will probably be
changing in subsequent versions. The proposed change is of the form:
<connectionParameters>
   <entry key="">value</entry>
</connectionParameters>
This should solve the conflict...
Patel, Ronak Avinash (US SSA) wrote:
Justin,
There's a conflict that I see...the url type is defined twice in two
different ways...such as:
<coverageStore>
  <name>arcGridSample</name>
  <enabled>true</enabled>
  <workspace>
    <name>nurc</name>
    <atom:link xmlns:atom="http://www.w3.org/2005/Atom&quot;
rel="alternate"
href="http://localhost:8080/geoserver/rest/worksapces/nurc.xml&quot;
type="application/xml"/>
  </workspace>
  <type>ArcGrid</type>
* <url>file:coverages/arc_sample/precip30min.asc</url>*
  <coverages>
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/nurc/coveragestore
s/arcGridSample/coverages.xml"
  </coverages>
</coverageStore>
And
***<dataStore>*
*** <name>*states_shapefile***</name>*
*** <enabled>*true***</enabled>*
*** <workspace>*
   *** <name>*topp***</name>*
   *** <atom:link* xmlns:atom="http://www.w3.org/2005/Atom&quot;
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/topp.xml&quot;
type="application/xml"***/>*
*** </workspace>*
*** <connectionParameters>*
   *** <namespace>*
     *** <string>*http://www.openplans.org/topp***&lt;/string&gt;\*
   *** </namespace>*
   *** <url>*
     *** <string>*file:data/shapefiles/states.shp***</string>*
   *** </url>*
*** </connectionParameters>*
*** <featureTypes>*
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/topp/datastores/st
ates_shapefile/featuretypes.xml"
*** </featureTypes>*
***</dataStore>*
So it seems that the url element is a complexType and a simpleType??
It
can't be both...
Sent: Tuesday, March 31, 2009 10:44 AM
Another question,
How can I specify which coverages I want to appear in which layers?
And...do I need to use Styles in order to make layers?
Well first you have to add the coverage. This will implicitly create a
layer for you which references the coverage under the name
<ws>:<coverageName>
You should be able to create a layer without specifying a default
style,
but one will be assigned to it implicitly.
I don't intend to reverse engineer the whole thing...just the parts
that
I need so I can get moving.
Ronak
Sent: Tuesday, March 31, 2009 10:14 AM
Nope, pretty much spread out across the globe from Vancouver to
Sydney
:slight_smile:
> I'm also on PST...I thought you guys were all in Europe...
> Sent: Tuesday, March 31, 2009 10:06 AM
> I will be around for 2-3 more hours, and then online later tonight
> (PST).
>> Justin,
>> Yes, I am doing that now...kinda have to just to fill out values
so I
>> can POST and GET and make sense of the data.
>> It's very hard to traverse a DOM when you don't know what the DOM
even
>> looks like....
>> I will send it to you for review before I start to use it in my
>> application.
>> How long will you be available today?
>> Thanks!
>> Ronak
>> Sent: Tuesday, March 31, 2009 10:01 AM
>> Well... xstream is nice and simple. You do not need to define a
schema
>> or antyhing to serialize and deserialize objects. We also had a
bunch
> of
>> a xstream based stuff around for serializing the exact same
objects,
> so
>> it made sense to reuse it.
>> Part of my hesitation of publishing a schema at this point is that
> this
>> api is very new, and will undoubtedly change. But I realize this
makes
>> it hard for the client since there is no great way to figure out
what
> a
>> legal representation is.
>> Anyways, if you do reverse engineer a schema and would be willing
to
>> share it I would be happy to review it, and incorporate it into
the
> api.
>> -Justin
>>> In the meantime, I'll have to improvise and make up the schema on
my
>> own
>>> based on the data I see in the examples on your site.
>>> Why did your team decide to use XStream rather than the popular
JAXB
>> or
>>> XMLBeans Java <-> XML binding APIs?
>>> Sent: Tuesday, March 31, 2009 5:43 AM
>>>> Hi,
>>>> I am exploring the new REST Configuration API and I was curious
> about
>>>> the XML datatype.
>>>> Do you provide an XSD schema that lists the type of data
structures
>>> that
>>>> would be returned from geoserver?
>>> Unfortunately no, not yet. The library we use (XStream) does not
>> provide
>>> any facility for generating an XML schema, nor should it really.
So
>> one
>>> thing I was was thinking of was coming up with one manually, but
>>> something i have not got around with.
>>>> This would work out well with a JAXB or XMLBeans.
>>> Another thing I would like to do is publish a java based client
api.
>>> Actually there is a summer of code project for this. That way
client
>>> code would really have to worry about what the exact XML
>> representation
>>> looks like.
>>>> Thanks!!
>>>> Ronak Patel
>>>> _______________________________________________
>>>> Geoserver-users mailing list
>>>> Geoserver-users@lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira
