Justin,
I'm not quite finished, but this is what I have so far:
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, March 31, 2009 12:00 PM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST Configuration API
Documentation is in the works. What you see there is as far as we have
gotten. Another good source of examples (again with curl) is available
in our svn repo:
http://svn.codehaus.org/geoserver/branches/1.7.x/src/extension/restconfi
g/scripts/
Basically it contains some shell scripts that build up the vanilla
geoserver configuration directory from scratch.
Hope that helps.
Patel, Ronak Avinash (US SSA) wrote:
Justin,
I also noticed that while the API provides good docs on how data can
be
retrieved, but is there more examples of how to POST content?
I saw the CURL examples...but I'm wondering about coverages and
layers...which parameters are required? Which ones aren't?Is there any other documentation I can read regarding that?
Ronak
Sent: Tuesday, March 31, 2009 11:51 AM
Subject: Re: [Geoserver-users] REST Configuration APIWell the connectionParameters will be open ended. So I suggest just
making its content extensible, perhaps making it xs:any or something.Also there is a bug in the current encoding so it will probably be
changing in subsequent versions. The proposed change is of the form:<connectionParameters>
<entry key="">value</entry>
</connectionParameters>This should solve the conflict...
Justin,
There's a conflict that I see...the url type is defined twice in two
different ways...such as:<coverageStore>
<name>arcGridSample</name>
<enabled>true</enabled>
<workspace>
<name>nurc</name>
<atom:link xmlns:atom="http://www.w3.org/2005/Atom"
rel="alternate"
href="http://localhost:8080/geoserver/rest/worksapces/nurc.xml"
type="application/xml"/></workspace>
<type>ArcGrid</type>
* <url>file:coverages/arc_sample/precip30min.asc</url>*
<coverages>
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/nurc/coveragestore
s/arcGridSample/coverages.xml"
</coverages>
</coverageStore>
And
***<dataStore>*
*** <name>*states_shapefile***</name>*
*** <enabled>*true***</enabled>*
*** <workspace>*
*** <name>*topp***</name>*
*** <atom:link* xmlns:atom="http://www.w3.org/2005/Atom"
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/topp.xml"
type="application/xml"***/>**** </workspace>*
*** <connectionParameters>*
*** <namespace>*
*** <string>*http://www.openplans.org/topp***</string>\*
*** </namespace>*
*** <url>*
*** <string>*file:data/shapefiles/states.shp***</string>*
*** </url>*
*** </connectionParameters>*
*** <featureTypes>*
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/topp/datastores/st
ates_shapefile/featuretypes.xml"
*** </featureTypes>*
***</dataStore>*
So it seems that the url element is a complexType and a simpleType??
It
can't be both...
Sent: Tuesday, March 31, 2009 10:44 AM
Subject: Re: [Geoserver-users] REST Configuration APIPatel, Ronak Avinash (US SSA) wrote:
Another question,
How can I specify which coverages I want to appear in which layers?
And...do I need to use Styles in order to make layers?Well first you have to add the coverage. This will implicitly create
a
layer for you which references the coverage under the name
<ws>:<coverageName>
You should be able to create a layer without specifying a default
style,
but one will be assigned to it implicitly.
I don't intend to reverse engineer the whole thing...just the parts
that
I need so I can get moving.
Ronak
Sent: Tuesday, March 31, 2009 10:14 AM
Nope, pretty much spread out across the globe from Vancouver toSydney
Patel, Ronak Avinash (US SSA) wrote:I'm also on PST...I thought you guys were all in Europe...
Sent: Tuesday, March 31, 2009 10:06 AM
I will be around for 2-3 more hours, and then online later tonight
(PST).
Patel, Ronak Avinash (US SSA) wrote:Justin,
Yes, I am doing that now...kinda have to just to fill out valuesso I
can POST and GET and make sense of the data.
It's very hard to traverse a DOM when you don't know what the DOMeven
looks like....
I will send it to you for review before I start to use it in my
application.
How long will you be available today?
Thanks!
Ronak
Sent: Tuesday, March 31, 2009 10:01 AM
Well... xstream is nice and simple. You do not need to define aschema
or antyhing to serialize and deserialize objects. We also had a
bunch
of
a xstream based stuff around for serializing the exact same
objects,
so
it made sense to reuse it.
Part of my hesitation of publishing a schema at this point is thatthis
api is very new, and will undoubtedly change. But I realize this
makes
it hard for the client since there is no great way to figure out
what
a
legal representation is.
Anyways, if you do reverse engineer a schema and would be willingto
share it I would be happy to review it, and incorporate it into
the
api.
-Justin
Patel, Ronak Avinash (US SSA) wrote:In the meantime, I'll have to improvise and make up the schema on
my
own
based on the data I see in the examples on your site.
Why did your team decide to use XStream rather than the popularJAXB
or
XMLBeans Java <-> XML binding APIs?
Sent: Tuesday, March 31, 2009 5:43 AM
Patel, Ronak Avinash (US SSA) wrote:Hi,
I am exploring the new REST Configuration API and I was curiousabout
the XML datatype.
Do you provide an XSD schema that lists the type of datastructures
that
would be returned from geoserver?
Unfortunately no, not yet. The library we use (XStream) does not
provide
any facility for generating an XML schema, nor should it really.
So
one
thing I was was thinking of was coming up with one manually, but
something i have not got around with.This would work out well with a JAXB or XMLBeans.
Another thing I would like to do is publish a java based client
api.
Actually there is a summer of code project for this. That way
client
code would really have to worry about what the exact XML
representation
looks like.
Thanks!!
Ronak Patel
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users--
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira
geoserver.xsd (8.84 KB)
