Patel, Ronak Avinash (US SSA) wrote:
Justin,
Unfortunately that schema does not compile because ATOM/RSS has no
schema...I wonder why you chose to use the atom link instead of one of the other
built in types or making your own type...
Using atom to link to resources with RESTful services seems like a pretty common practice. And atom:link seemed to perfectly fit this situation. What other built-in type are you referring to?
But anyway, I've resorted to just create the xml in my code by appending
string together in stringbuffers....it's crude and dangerous xml
programming but I don't have much time...Hopefully the next version of geoserver will take these considerations
when putting out a REST API.Thanks for your help!
Ronak
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Wednesday, April 01, 2009 11:40 AM
To: Patel, Ronak Avinash (US SSA)
Subject: Re: [Geoserver-users] REST Configuration APIGreat, thanks Ronak. When I get some free time I will try to give it an in depth review. And hopefully hook it up to our test cases to ensure what geoserver spits out and what it accepts is validated against the schema. Thanks again!!
Justin,
I'm not quite finished, but this is what I have so far:
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, March 31, 2009 12:00 PM
Subject: Re: [Geoserver-users] REST Configuration APIDocumentation is in the works. What you see there is as far as we have
gotten. Another good source of examples (again with curl) is available
in our svn repo:
http://svn.codehaus.org/geoserver/branches/1.7.x/src/extension/restconfi
g/scripts/
Basically it contains some shell scripts that build up the vanilla geoserver configuration directory from scratch.
Hope that helps.
Justin,
I also noticed that while the API provides good docs on how data can
be
retrieved, but is there more examples of how to POST content?
I saw the CURL examples...but I'm wondering about coverages and
layers...which parameters are required? Which ones aren't?Is there any other documentation I can read regarding that?
Ronak
From: Justin Deoliveira [mailto:jdeolive@anonymised.com] Sent: Tuesday, March 31, 2009 11:51 AM
Subject: Re: [Geoserver-users] REST Configuration APIWell the connectionParameters will be open ended. So I suggest just making its content extensible, perhaps making it xs:any or something.
Also there is a bug in the current encoding so it will probably be changing in subsequent versions. The proposed change is of the form:
<connectionParameters>
<entry key="">value</entry>
</connectionParameters>This should solve the conflict...
Justin,
There's a conflict that I see...the url type is defined twice in two
different ways...such as:
<coverageStore>
<name>arcGridSample</name>
<enabled>true</enabled>
<workspace>
<name>nurc</name>
<atom:link xmlns:atom="http://www.w3.org/2005/Atom"
rel="alternate"
href="http://localhost:8080/geoserver/rest/worksapces/nurc.xml" type="application/xml"/>
</workspace>
<type>ArcGrid</type>
* <url>file:coverages/arc_sample/precip30min.asc</url>*
<coverages>
rel="alternate"
href="http://localhost:8080/geoserver/rest/workspaces/nurc/coveragestore
s/arcGridSample/coverages.xml"
</coverages>
</coverageStore>
And
***<dataStore>*
*** <name>*states_shapefile***</name>*
*** <enabled>*true***</enabled>*
*** <workspace>*
*** <name>*topp***</name>*
*** <atom:link* xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver/rest/workspaces/topp.xml" type="application/xml"***/>*
*** </workspace>*
*** <connectionParameters>*
*** <namespace>*
*** <string>*http://www.openplans.org/topp***</string>\*
*** </namespace>*
*** <url>*
*** <string>*file:data/shapefiles/states.shp***</string>*
*** </url>*
*** </connectionParameters>*
*** <featureTypes>*
href="http://localhost:8080/geoserver/rest/workspaces/topp/datastores/st
ates_shapefile/featuretypes.xml"
*** </featureTypes>*
***</dataStore>*
So it seems that the url element is a complexType and a simpleType??
It
can't be both...
Sent: Tuesday, March 31, 2009 10:44 AM
Subject: Re: [Geoserver-users] REST Configuration APIPatel, Ronak Avinash (US SSA) wrote:
Another question,
How can I specify which coverages I want to appear in whichlayers?
And...do I need to use Styles in order to make layers?
Well first you have to add the coverage. This will implicitly create
a
layer for you which references the coverage under the name
<ws>:<coverageName>
You should be able to create a layer without specifying a default
style,
but one will be assigned to it implicitly.
I don't intend to reverse engineer the whole thing...just the
parts
that
I need so I can get moving.
Ronak
Sent: Tuesday, March 31, 2009 10:14 AM
Nope, pretty much spread out across the globe from Vancouver toSydney
Patel, Ronak Avinash (US SSA) wrote:I'm also on PST...I thought you guys were all in Europe...
Sent: Tuesday, March 31, 2009 10:06 AM
I will be around for 2-3 more hours, and then online later tonight
(PST).
Patel, Ronak Avinash (US SSA) wrote:Justin,
Yes, I am doing that now...kinda have to just to fill out valuesso I
can POST and GET and make sense of the data.
It's very hard to traverse a DOM when you don't know what the DOMeven
looks like....
I will send it to you for review before I start to use it in my
application.
How long will you be available today?
Thanks!
Ronak
Sent: Tuesday, March 31, 2009 10:01 AM
Well... xstream is nice and simple. You do not need to define aschema
or antyhing to serialize and deserialize objects. We also had a
bunch
of
a xstream based stuff around for serializing the exact same
objects,
so
it made sense to reuse it.
Part of my hesitation of publishing a schema at this point isthat
this
api is very new, and will undoubtedly change. But I realize this
makes
it hard for the client since there is no great way to figure out
what
a
legal representation is.
Anyways, if you do reverse engineer a schema and would be willingto
share it I would be happy to review it, and incorporate it into
the
api.
-Justin
Patel, Ronak Avinash (US SSA) wrote:In the meantime, I'll have to improvise and make up the schema
on
my
own
based on the data I see in the examples on your site.
Why did your team decide to use XStream rather than the popularJAXB
or
XMLBeans Java <-> XML binding APIs?
Sent: Tuesday, March 31, 2009 5:43 AM
Patel, Ronak Avinash (US SSA) wrote:Hi,
I am exploring the new REST Configuration API and I was curiousabout
the XML datatype.
Do you provide an XSD schema that lists the type of datastructures
that
would be returned from geoserver?
Unfortunately no, not yet. The library we use (XStream) does not
provide
any facility for generating an XML schema, nor should it really.
So
one
thing I was was thinking of was coming up with one manually, but
something i have not got around with.This would work out well with a JAXB or XMLBeans.
Another thing I would like to do is publish a java based client
api.
Actually there is a summer of code project for this. That way
client
code would really have to worry about what the exact XML
representation
looks like.
Thanks!!
Ronak Patel------------------------------------------------------------------------
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users--
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira
