I saw the link to download Geoserver nightly build at:
http://geoserver.org/display/GEOS/Nightly
Where do I download the nightly build of the plugin?
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: Tuesday, April 14, 2009 11:29 AM
To: Patel, Ronak Avinash (US SSA)
Cc: geoserver-users@lists.sourceforge.net; Froumis, James A (US SSA)
Subject: Re: [Geoserver-users] REST Configuration API
Both, they both contain a few related bug fixes not in the 1.7.3
release.
Patel, Ronak Avinash (US SSA) wrote:
The nightly build of geoserver? Or the plugin?
Sent: Tuesday, April 14, 2009 11:26 AM
Subject: Re: [Geoserver-users] REST Configuration APIOk, this fix went in after 1.7.3. Is there any chance you could try it
out with the latest nightly build? That will at least give us the
exception that is occurring. Sorry for the inconvenience.-Justin
I downloaded the latest stable build 1.7.3a. I just downloaded that
and
the REST plugin from geoserver.org today.
Sent: Tuesday, April 14, 2009 11:24 AM
Subject: Re: [Geoserver-users] REST Configuration APIHmmm... I am still not seeing the exception in the logs. Come to
think
of it I think i added the logging statement in my latest patch to fix
the related issue. What build are you running?
Hi Justin,
I set the logs to verbose like you said and I get the following
error:
14 Apr 11:13:33 DEBUG [geoserver.filters] - filtering
http://patel-dev.irad.net:8080/geoserver/rest/workspaces/leia11/coverage
stores/blah/file.geotiff
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - ConvertedURL
to lowercase, from:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; to:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff' and
httpMethod= PUT
antPath= /** methodList= [Ljava.lang.String;@893918
method[0]:
GET
[security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidateis:
'/rest/workspaces/leia11/coveragestores/blah/file.geotiff'; antPath
is
/**; matchedPath=true; matchedMethods=false
antPath= /** methodList= [Ljava.lang.String;@327236
method[0]:
POST
method[1]:
DELETE
method[2]:
PUT
is
/**; matchedPath=true; matchedMethods=true
14 Apr 11:13:33 DEBUG [gce.arcgrid] - ArcGridFormatFactory is
availaible.
14 Apr 11:13:33 DEBUG [gce.arcgrid] - Creating a new ArcGriFormat.
14 Apr 11:13:33 INFO [catalog.rest] - PUT file, mimetype:image/geotiff
14 Apr 11:13:33 INFO [catalog.rest] - Using existing coverage store:
blah
availaible.
14 Apr 11:13:33 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerExceptionLike you said, I blow away the contents of the
/opt/geoserver-1.7.3/data_dir/data/coveragestorename to get rid of
my
geotiff file.
I see that the HTTP PUT does indeed upload my file to geoserver
fine.
The problem seems to be with processing the geotiff file after a
successfull upload.Hopefully this is helpful.
Ronak Patel
Sent: Tuesday, April 14, 2009 10:43 AM
Subject: Re: [Geoserver-users] REST Configuration APIHi Patel,
Can you log into the admin console and turn on verbose logging.
Config -> Server and change logging to GEOSERVER_DEVELOPER. And then
try
again including the stack trace from the error log.
Also, when files are uploaded they get put into the "data" directory
under neath GEOSERVER_DATA_DIR, you may want to try clearing out the
appropriate sub directories to ensure a "fresh" start. Which reminds
me
I fixed an issue recently with files not being able to overwrite
existing files, that might be coming into play here.Thanks,
-Justin
Justin,
By the way, I am actually PUTing the image to the server and NOT
POSTing.I keep getting this error when I try to upload a png or jpg:
14 Apr 10:00:08 INFO [catalog.rest] - PUT file, mimetype:
image/jpeg
14 Apr 10:00:08 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:08 ERROR [geoserver.rest] - Error auto-configuring
coverage:Unsupported file format
14 Apr 10:00:22 INFO [catalog.rest] - PUT file, mimetype: image/png
14 Apr 10:00:22 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:00:22 ERROR [geoserver.rest] - Error auto-configuring
coverage:Unsupported file formatWhen I try to upload a GeoTiff, I always get the following error:
14 Apr 10:03:49 INFO [catalog.rest] - PUT file, mimetype: image/tif
14 Apr 10:03:49 INFO [catalog.rest] - Using existing coverage
store:
blah
14 Apr 10:03:49 ERROR [geoserver.rest] - Error auto-configuring
coverage:java.lang.NullPointerExceptionI hope that helps in debugging the situation.
Thanks a million!!
Ronak Patel
Sent: Tuesday, April 14, 2009 9:50 AM
To: 'Justin Deoliveira'
SSA)
Subject: RE: [Geoserver-users] REST Configuration API
Justin,
I desperately tried all day yesterday to try to POST a coverage and
get
Geoserver to accept my image (a GeoTiff).
I am POSTing to a CoverageStore and Workspace that I create using
the
REST API.
I am POSTing the following:
URL:
/geoserver/rest/workspaces/testWorkspace/coveragestores/testStore/file.g
eotiff
POST ContentType image/tif and the POST content is the file.
I noticed that if I set the configure=none&coverageName=test flags
in
the URL, then the file is ingested by Geoserver without
complaining.
When I don't set these cgi parameters, things fail and complain.
Why does this happen?
Also, do I have to create a layer to host the image in the WMS? Or
is
this done automatically?
Thanks a million!!
Ronak Patel
Justin Deoliveira
OpenGeo - http://opengeo.org
